Jon's 4doorsupra 2j build (Na-t)
Old Apr 13, 2019 | 11:45 PM
  #31
KahnBB6's Avatar
KahnBB6
^^ That NA-T engine is starting to look mean. That big intake plenum will handle 400whp for sure. What you may find is that low end torque will be a bit less without the factory cross-over intake manifold. But that will be mitigated mostly by your choice of turbo on that Treadstone manifold if it can spool pretty quickly. Are you perhaps thinking of going with a 58mm or 62mm size for that projected power level?
For diff gearing to match the new engine in your MX73 are you going to use a 3.90 or 3.73 ratio from an MKIII?
Old Apr 14, 2019 | 11:34 PM
  #32
Kris9884's Avatar
Kris9884
Coming along nicely, sub'd
Old Apr 15, 2019 | 01:35 PM
  #33
73luxury's Avatar
73luxury
kilo
So i have a 60mm size and currently i have the stock 4.10 auto diff welded. I have a lsd from an auto mx73 but Im not sure what ratio it is I havent looked at it yet.
Old Apr 15, 2019 | 01:37 PM
  #34
73luxury's Avatar
73luxury
Thanks bro!
Old Apr 16, 2019 | 07:36 AM
  #35
RudysSC's Avatar
RudysSC
I ran my 2jzge swap through a w58 to a stock welded auto diff and didn't have any issues with gearing. I'm sure going NA-T could change that, but I don't remember any of the gears feeling too long or too short to be honest.
Old May 3, 2019 | 11:30 PM
  #36
73luxury's Avatar
73luxury
Yeah should be good, Im not too worried about running it like that for now main concern is to get this thing in the car first haha
Old May 3, 2019 | 11:47 PM
  #37
73luxury's Avatar
73luxury
Update: Mar 5, 2019
What's up! I installed the belt last month and haven't uploaded the pics since. I got around to cleaning and painting the belt covers, I'm really pleased on how they turned out. Bumper and trim paint is the bizz. Went for that oe look, not a huge fan of gloss.
For this months project, I'm going to work on the turbo rebuild! Stay tuned.. or shall I say stay boosted ya'll!
Old Jun 8, 2019 | 10:41 PM
  #38
73luxury's Avatar
73luxury
Update: Jun 8, 2019
What's up clublexus!! Here's the rebuild of my Holset HX35 turbo rebuild. I upgraded to the HX40 billet compressor wheel(60x86) and 10 blade turbine wheel. Switched from the stock internal wastegate exhaust housing to the undivided housing(.82 a/r vs .72). So I purchased the HX35 and it was completely rusted out and the compressor wheel was chewed up. I spent weeks soaking it in vinegar, pb blaster and the exhaust housing would not separate even with heat and a mallet lol. So the turbo has all new components, except for the compressor housing, which was machined to accept the larger billet wheel. I bought a garbage HX35 for $200 and spent $550 to do this rebuild, so in total I spent $750 for a rebuild turbo. The wheels were balanced as an assembly and the compressor housing was machined by Turbolabofamerica. In short, I have a HX35 with HX40 guts.
Old Jun 8, 2019 | 10:53 PM
  #39
73luxury's Avatar
73luxury
Here's the comparison of the stock divided and the new undivided housings. Dont mind my bent clamp lol
Old Jun 10, 2019 | 09:37 AM
  #40
silentkill's Avatar
silentkill
Pretty sure you can use Q45 TB on those intakes, my friend has?
Old Jun 10, 2019 | 12:09 PM
  #41
73luxury's Avatar
73luxury
I have a q45 tb and the bolt holes dont match. What do you mean
Old Sep 27, 2019 | 07:22 PM
  #42
73luxury's Avatar
73luxury
Update: Sep 27, 2019
Hey whats up guys, its been 3 months since I've been on here. Just had a baby and haven't had the time or energy to upload stuff.. but the 2j is almost ready. Brace yourselves for the photo dump!! Enjoy
Found shorter OEM bolts to fit the treadstone manifold
BYE BYE 5mge its been a good 6 years
Dirty old girl
Mostly everything removed and power washed to see what I have to work with.
Sanding and removing seam sealer, Attempted to weld all unwanted holes for a cleaner bay, but time was not on my side so I just used metal filler.
Appled new seam sealer
Time for paint!
Old Sep 27, 2019 | 07:25 PM
  #43
73luxury's Avatar
73luxury
First coat of high fill primer, I did 3 coats but didn't take photos of all stages
First coat of super white Toyota factory color. code 040
Cleaned off the subframe it was covered in layers of oil
More paint... and decided to paint the rails black for cost purposes.
Flywheel resurfaced and went with ACT extreme clutch kit
Well hello there. Cressida meet jz, Jz meet cressida.
Bought a remanufactured rack because my old one was leaking and its much easier to install one when the motor is out anyways
And shes finally in after 4 weekends of painting and $200 of paint, now the real run begins.
My goal was to have it running by summer, oh wait oops its almost fall... I guess I'll shoot for the end of the year to be more realistic haha
2023 update! Got caught up with getting the car running and put back together, here’s a photo dump since the engine bay post.
8/20/19
Old Mar 7, 2023 | 09:11 PM
  #44
73luxury's Avatar
73luxury
Default More pics
Alternator relocation bracket with ls430 high amp alternator
Belt fits perfectly
-10an oil drain
Ric flair drip
New coolant hoses
Repositioned mounts to have rad sit flush
Old Mar 7, 2023 | 09:19 PM
  #45
73luxury's Avatar
73luxury
Intercooler fits behind hood latch. Not a fan of hood pins, nothing hood bout me lol
Corrected valve lash
Hot side
0 gauge ground
Hood exit mocked up
Can’t go wrong with these bad boys
My buddy did my harness plug and play 3 years strong. All oem style clips for turnkey application. If you need custom wiring hit me up!
Vibration eliminator
Home made 3” down for the budget build
update** 3-28-24 sheesh
a few years later
I’ve been enjoying the motor, I never updated this thread but it has been running perfectly. It’s been through 3 track days since with no issues. Planning on upgrading the ecu and injectors this year.
High pressure line adapted to AN fittings
IAT installed
IACV flange fabbed up
