Broke Busted Build
#31
The perch is fixed. You might machine down the perch some. There’s a bit of meat there.
The ride is much less harsh. It doesn’t settle as quickly over big hits though. I’d say it could use for a bit more rebound damping.
It’s hard to know how OEM replacements would compare.
#32
I also made a few relevant threads...
Printable profile for ISF
https://www.clublexus.com/forums/is-...f-profile.html
Weird 3D printed phone holder for ISF ash-tray (not great)
https://www.clublexus.com/forums/is-...ne-holder.html
Condensed ISF Transmission fluid change and level set procedure (don't search the mother thread... too long)
https://www.clublexus.com/forums/is-...procedure.html
On ISF OEM Spring rates:
https://www.clublexus.com/forums/is-...ing-rates.html
How to use RCF mirror in ISF (pre 2010)
https://www.clublexus.com/forums/is-...is350-isf.html
JT2MA71 (01-25-22)
#34
Yeah those clips look pretty easy, but the swivel will be a challenge. I'm guessing that's a type of snap together thing?
I can print in ABS and that would probably hold up for a while, but if the OEM clips fail there's a good chance these would too.
If you can send me some measurements. Or just take a picture of it in front of some graph paper and a ruler. I'll try to make a drawing. It might need to be 3 pieces if I can't figure out the snapfit.
I'm also doing daddy daycare due to COVID this week.
#36
Received 1,058 Likes
The OEM clip breaks after it’s been messed with…
This is located on the driver’s side next / in front of brake booster next to master cylinder..
Swivel is not important we just want it to lock 2 lines in place..
Just needs to be flexible but strong and exact specs if you scan an unbroken original one.
engine covers removed..
Joe Z
Joe Z
#37
Mine is busted too. Looking at your photo and then putting pressure on my lines…. I’d say it’s likely the part would break without significant deviations from the OEM design. A printed part will always be weaker than a cast part.
The swivel does seem to be important in allowing the lines to remain non parallel. So fiddling around with the angle would be required if the swivel were deleted.
I don’t have the time to fiddle with it. Im guessing you’ve looked at grainger or McMaster?
im wondering if the swivel/snap just allows mixing and matching diameters.
Sorry. If someone wanted to scan it I’ll print parts, but honestly, anyone with a scanner has a print farm.
#38
You may be about to lose respect for me here, but Won’t a slightly lose zip tie function without issue?
#39
Tech Info Resource
It functions just fine without the clip. AMHIK.
The wife's GS F has the exact same clip. It's in the pic on Joe's post, I took that shot.
#40
quick ones: will the car feel soft on bilsteins? no, just softer than factory. will the car handle better? IMO yes. okay, but I want my car to be comfortable: bilsteins are not for comfort. ride will still be firm, but less firm than factory.
Generally, 7 out of 10 people say that bilstein's (b6/b8) ride firmer than they expected. However, the ISF comes with such a firm ride from the factory that bilsteins actually feel softer in comparison.
PJSnow (05-11-22)
lobuxracer (06-15-22)
I8ABMR
11-23-17 08:02 PM
