engine swap
engine swap
hi i have a 2009 is250 rwd automatic, i was planning on swapping the engine with a 2011 is250 rwd as well, i was wondering if it would be a direct swap or if i would need new wiring harness and ecu and end clips? thank you
Drizell (10-31-18)
So i missed that boat but i found a 2011 awd is250 would that make any difference ?
So the engine i was planning to swap is out of a 2011 awd is250 would that ve a direct swap as well or does the awd change anything ? Thank you for any help possible
frank12933
10-24-17 07:00 PM
