Vince's NA-T college fun build
#110
Alright fellas. Me and my dad drilled it. We used grease and all with a hole saw. We are still cleaing it out and will tap the sides right now. I got my finger in there and got most of the shavings out. They are reaalllllyyyy fine too. Super tiny. Will be back with another update very shortly.
Funky, I know lol
Funky, I know lol
#111
Big problem ou of the way.
Alright. All done hopefully. Cleaned out the insde with some scotch brite and a cotton swab AND compressed air. Im aware some super small shavings may have snuck past me but Im confident the oil pick up screen on the pump should pick them up. Used double split washers on each stud just in case since there was some dead thread peaking through. Now to get this build done.
Theres the hole.
Theres the double split washers
As always, any advice, throw it at me. Thanks fellas hope to hear from yall soon!
Theres the hole.
#112
Theres the hole.
Theres the hole.
#113
Ayeo! So I tried putting the flange thing on and when tightened it lines up to the side (15° to be exact) instead of straight up (90°). I imagine this is an issue. Cant run that thing a lil loose I imagine so, what to do?
Dat boi right there.
#117
Gotcha. Okay so I should use plumbers on my oil feed off the adapter BUT use locktight for the adapter itself. Use plumbers for the oil return at the bottom and thats it I think?
#118
Headaches after headaches....
So. After getting pretty good progress and getting this dang project moving. Ive hit another headache..... the oil kits 45 doesnt clear the XS power manifold... Also I checked the turbo and it had some play. Not alot. It was still very stiff but you could tell it isnt perfect. Man this is starting to get fustrating but thats nat builds right?
Oil return hitting manifold.
Turbo not clearing due to oil return. Clocked 10 ish degrees
Hope to hear from yall soon
#119
You're going to have to loosen the black oil return fitting and turn the 45 degree until it clears the manifold. To do this, you will have to remove the other end of the oil line from the oil pan, if it is already connected.
This is an issue with the smaller frame turbos. Had the same issue with my old precision 6176. Larger turbos have a larger cartridge which moved the oil lines out further from the flange.
#120
So its not connect but the thing is if I move the 45 anywhere. It scrapes the manifold.. i had it at its lowest point and it still scratched the manifold.
