Blown valve cover gasket caused by pcv?
Old 09-17-18, 08:57 AM
Kal333
Kal333's Avatar
Default Blown valve cover gasket caused by pcv?
There was oil pooling under my car after running, got out to the sound of sizzling and smoke and smell of burnt oil. Clearly, my pcv valve has failed and I'm guessing caused a blown cover gasket. There was a slight collection of oil above the left head here. There seems to be a lot of grime on that side of the engine as well. Seems to have been a problem for a while. Ordered valve cover gasket and pcv valve. Is there anything else I should be looking for to replace in there?
Old 09-17-18, 09:04 AM
Kal333
Kal333's Avatar
Here's photos
Old 09-17-18, 09:08 AM
Kal333
Kal333's Avatar
Old 12-26-18, 03:54 PM
YODAONE
YODAONE's Avatar
Originally Posted by Kal333
If original, replace left and right bank PCV system hoses, clamps, PCV valve, and PCV grommet....
Age and heat hardened rubber does not seal well.
Also replace both valve cover gaskets, valve cover bolt sealing washers, oil fill cap gasket and spark plug tube seals...
You will require FIPG for application in certain areas of new valve cover gasket and cam wedges (half moon shaped plugs used to fill void
Before removing valve covers seriously clean them and surrounding area to prevent grit from falling into engine.
at back of head after head is machined for camshaft)...use Toyota 00295-00103
If unsure about any of this, check out a Lexus shop manual or hire an experienced wrench.
DerekD1010
04-19-17 11:21 PM
durtysc300
SC- 1st Gen (1992-2000)
08-20-11 10:36 AM
kino1161OL
GS - 1st Gen (1993-1997)
12
03-26-07 08:46 PM
dejacky
Maintenance
10-27-05 04:16 PM
Spencer
Performance & Maintenance
02-27-04 12:50 PM
Quick Reply: Blown valve cover gasket caused by pcv?
