630whp 698wtq SC400 TURBO 1UZ !!
Hello everyone, My name is Sean and wanted to share my build Ive been working on for the last 3 years. This is my 97 SC400 with a custom RareFab turbo kit. When I got the car the motor was swapped to a pre 95 to utilize the thicker rods the motor had. This made it easier to add more boost without a built motor. I too later swapped in another pre 95 1uz motor but added ARP head studs, cometic MLS head gaskets, and upgraded valve springs. My goal was to reach passed the 500 whp mark without an extensive build. Here are the specs and stats. Im sure I will forget a bunch of stuff but if you have any ?? just ask.
Car currently makes 630whp 698wtq. 20lbs of boost on E85 fuel.
SPECS
1. Stock bottom end 94 1uzfe with added MLS HG, ARP head studs, and upgraded valve springs.
2 .Factory Nissan 350Z CD009 6 speed manual swap w/collins adapter kit
3. Custom single turbo kit by RareFab. BW S366 turbo, Tail wats gate and BOV.
4. Custom cooling system by RareFab
5. Custom single 4" exhaust by RareFab
6. Custom rear subframe with 8.8 FORD rear end, Spool diff, level 10 axles, and all bushings and trailing arms upgraded. Not on the car yet.
7. Weapon X super COP set up
8. Halleffect sensor swap
9. EV14 Bosh modified injectors. Flow tested to 950cc
10. E85 fuel
Apperance
1. Aero kit that includes front splitter,side splitters,air duct in front bumber, and rear diffuser. All custom made by RareFab.
2. KBD over fenders 50mm.
3. Big Country Lab 1850mm carbon rear wing....it was a lot bigger then anticipated...
4. JDM side markers.
5. Volk GTV 19" wheels show and daily shoes / Weld racing big and littles RTS ..my dancing shoes
6. 3M Dragon Fire Red gloss wrap.
7. Seibon CF hood.
8. O.G custom headlights. Sequential switchable running lights, larger projectors with halos.
Interior
1. Sparco RS100 racing seats
2. Sparco harness bar.
3. Custom sparco shift boot.
4. Sparco 4 point harness RED.
5. Sparco shift ****.
6. Rear seat delete ( Not installed yet )
7. Sparco sterring wheel.
Vids
My IG is @sc400turbov8 follow for updates and more vids!
SPECS
10. E85 fuel
Apperance
7. Seibon CF hood.
Interior
Vids
DaveGS4 (03-13-18)
Spectacular! Love the time and care that went into utilizing the 1UZ. Excellent build, thank you for sharing!
Boosted1UZ (03-12-18)
Boosted1UZ (03-13-18)
Boosted1UZ (03-14-18)
Boosted1UZ (10-24-18)
Boosted1UZ (03-16-18)
