Kyles SC400T Build
#91
Fabricated legs for the engine, to get rid of the engine stand and allow for transmission attachment
Transferring the engine to the legs
They hold up great!
The first day in weeks with no rain or snow forecast. Everyone outside for a garage cleanup!
The custom transmission finally arrived. The project has been on hold waiting for this
The size difference is concerning, but I have seen SC300 builds with the 4L80. Hopefully it will fit with no cutting...
Kyleg250z (02-09-19)
#93
16 Ga. cover for the hole where the old shifter was
Adapter plate fitted
Some clearanceing to allow the wire harness to fit
Removing the bellhousing to hone the dowel pin holes to .6250". Both the engine and transmsission sides were a press fit, one needed to be a slip fit.
Back together, with aluminum torque converter adapter
Custom made "presser" to install the torque converter snout adapter. It was a .002" press fit.
Installed
The wood is preventing the torque converter from sliding off
Using the crane allowed for fine angle adjustment, and made installation a breeze
#94
I feel like most people would have just swapped in the LS that trans used to mate with... But i like watching this a whole lot more 👍
man that engine balancer on your hoist had to be so nice when lining up that heavy @$$ trans!
keep that UZ alive! I swear 75% of people who ask if i have a 300 or 400 automatically ask if im gonna jz or ls swap it once i say 400. and the response is always why would i do that?
Nothing wrong with the UZ theyre great engines. As are the jz and ls.. But if youve got one to begin with why toss it for another?
Kyleg250z (02-24-19)
#96
Using a dial indicator I found the flex plate had a run out of 0.040", where the factory spec is 0.007. My spare plate has heavy rust on it, so engine installation is postponed while I wait for a new one from the dealer.
Finished PRNDL adapter
Mounting plate for the B&M shifter. The cut out is to allow a 4th bolt to go through the adapter plate into the car
Shifter fits well
This is the final fitment in the car, the surround needs a little trimming. I think the gear indicator on both the dash board and shifter surround will still work
Shifter fits well
#97
You got me as giddy as a school girl over here Kyle!
#98
Fitting the transmission has been a mission. I've had to cut out 2 sections of the body, and "massage" in 3-4 others with a 4lb sledge to fit it. In order to get a proper/stock drive shaft angle, it needs to tuck up tight into the car, with the pan's flange above the chassis. Each time an adjustment or cut out needs to be made, the engine and transmission need to be hauled out of the car with a jack and crane. As it sits now, everything fits but there is not enough space for the shifter to rotate. That will be up next!
I'm keen for a first start, to see if the engine has any issues from a garage assembly.
Shiny new flex plate
To give an idea of how high up the trans needs to be
Cut out for the shift rod and electrical plug
The SFI bell housing makes fitment even tighter
Wiring in new relays and fuses to power the LS coils
#99
Man youre killin it! Great progress 👍
the taking the whole setup in and out over and over is always such a motivation killer for me after about the 3rd time.
How far are you from final fitment and fabbing up a mount?
#101
Hell ya, keep it up! Can't wait to see you turn this thing over.
#102
Thanks, this is a killer tip. I would be all over it if I did not need to pull the pan off to get access. It still might be necessary if I cant make enough space in the floor.
Thanks for the encouragement
#103
Started trans mount
Welded tube into the horizontal holes to support clamping force of the bolts
Shifter surround finished: Park position
1st gear
Took StillOEM's advice and installed a short shift shaft
All wrapped up. OEM transmission angle was 1.8 degrees, we're at 2.4 now. Pretty good!
low-profile cooler fittings, flexible dipstick
Getting there, intake manifold is back on
#105
Went to do a first start, and the starter wouldn't turn over. Verified wire/signal integrity right up to the starter. A hammer didn't help either, the solenoid draws current but seems to be stuck. With the transmission adapter, the starter is an engine-out job. Currently prepping to pull everything again, and there is a re-man Denso unit on order
The amusing part is, I used the working starter motor out of my original engine to avoid such an issue.
