The Bastard- Supra MkIV Lexus edition
The Bastard
wiper unit and air intake
Since everything between the windshield and firewall is reversed on a RHD car, it all had to be changed around.
First a couple of pics of the car still in RHD mode:
RHD: Wiper motor
RHD: Air intake
Removing the RHD wiper bracket
RHD: Wiper motor
RHD: Air intake
The Bastard
Removing RHD air intake cover
RHD air intake
Cutting out everything needed from the SC
This is the plate covering the RHD air intake hole on a LHD car. Same shape on the SC and supra
RHD air intake
The Bastard
On the inside it has bolt holes for the clutch pedal support
Welded in place
Testfitting the SC/LHD wiper bracket. Not an exact fit, but it could be adapted.
cutting a hole for the loom to the wiper motor.
Welded in place
The Bastard
To get it as accurate as possible, I had the parts attached to the wiper motor when I welded it in place.
The Bastard
Making a new air intake hole on the right side.
The hole for the RHD wiper loom to the right in the picture was closed.
The Bastard
Cover for the new LHD air intakte. Again not a perfect fit, but could be adapted.
Repainting everything after the LHD adaption.
The Bastard
: brake master cylinder and body harness
The SC/LHD brake master cylinder +TRAC. Perfec fitment
All the bolt holes where the same. Thank you Toyota!
same thing with the engine bay harness. Everything was bolt on.
The Bastard
: brake lines /abs
ABS unit + brake lines cleaned up.
Bolt on.
Tried everything with the hood on, just to make sure that there was enough space.
: brake lines /abs
Bolt on.
The Bastard
steering rack
LHD steering rack in place. The line behind the steering rack, from the coal canister has been changed as well.
sanded and repainted hood locks in place.
Repainted signal horn in place. Holding the SC horns for comparison. Same connectors.but a single smaller and lighter horn. Another weight saving change on the supra.
The line from the coal canister sanded and repainted.
steering rack
The Bastard
: Interior: Body harness
As you see in this picture, the SC is a bit longer, which makes the plastic cover on the harness a bit too long.
Modified plastic cover, to fit the shorter supra.
Small adjustments had to be done on the harness. This is behind the passenger seat.
The Bastard
:Interior: heater unit and dash board support
The SC “firewall carpet” fitted quite well. Had to do some small cuts in it here and there.
This is the main bracket for the heater/ac unit. SC bracket to the left. The heater/ac unit is the same in the sc and the supra, but all the brackets had to be modified. I used the SC brackets, since the Supra ones was for RHD and hence reversed.
