Build Threads Details on Club Lexus SC owner vehicles
CD009 350Z 6spd On 1JZ SC400
Old 06-20-16, 05:27 PM
  #466
LoveSCs
LoveSCs's Avatar
nice find on that mustang shifter. To be honest, you don't really need the cup since you are designing the "cup" into your piece. We only needed the cup to give a cavity for the ball to rotate in since that little linkage piece was so thin. But you are essentially designing that cavity into the piece by making it so deep. You could just wait until that mustang shifter came in and then design your cavity to that ball size if it is different than the 240sx one. That would be nice
But to be honest, it doesn't really bother me the fact that it's not perfectly center. At first I thought that it might, but it really doesn't
Old 06-20-16, 05:59 PM
  #467
Ali SC3
Ali SC3's Avatar
looks similar but just swan necked, might be easier to start from.
edit*
you can just get that bend put in to the 240 shifter, but it will be hard to do reverse lockout on that or the mustang with a bend in it.
I will be leaving it straight up and down so its nice and crisp, retains the reverse lockout with the brz or supra top half of the shifter, and use the auto plate (maybe change the wood trim for carbon fiber).
Old 06-22-16, 06:10 AM
  #468
Halon
Halon's Avatar
Someone was selling one of the mustang shifters for $36 shipped, so I just picked one up to check it out.
Old 06-22-16, 07:39 PM
  #469
Halon
Halon's Avatar
Time to get out the grinder.
Old 06-23-16, 05:53 AM
  #470
LoveSCs
LoveSCs's Avatar
Nice! Looks like a nice piece!
How long until you think you have it all back in?
Old 06-23-16, 06:30 AM
  #471
Halon
Halon's Avatar
Still waiting on the flywheel, but at least having this piece lets me start moving forward with some of the work. I think I have just about all the parts I need either in hand, or on order. So then it's just a matter of me getting things done, which is slow with our kids taking up most of my life. What I'll probably end up doing is taking a day off work here and there to power thru getting some of this done.
Also, I'm in the middle of switching over from MS3 to Infinity. So that's also going to slow things down a little.
Old 06-24-16, 08:01 PM
  #472
Halon
Halon's Avatar
Had a little time today. Got the bellhousing cut off. Got the input shaft cover removed. And got the little stud ground down.
I also got my mustang shifter in the mail today. It was missing the top shift lever piece so I have to return it. It is a hare less wide, so for the two mounting holes when you drill the hole large enough for an M8 it'll probably end up going through the sides a little bit. Not sure if that's a big deal or not. But I might just call this a lucky mistake and just return this for a refund, and not get another. I haven't decided yet.
Attached Thumbnails CD009 350Z 6spd On 1JZ SC400-20160624_212350.jpg   CD009 350Z 6spd On 1JZ SC400-20160624_143426.jpg   CD009 350Z 6spd On 1JZ SC400-20160624_150353.jpg   CD009 350Z 6spd On 1JZ SC400-20160624_160650.jpg
Old 06-29-16, 03:08 PM
  #473
Halon
Halon's Avatar
Got the adapter plate mounted to the trans today.
Old 06-29-16, 04:03 PM
  #474
driftdan
driftdan's Avatar
I need the measurements of that trans mount plz
Old 06-29-16, 04:19 PM
  #475
Halon
Halon's Avatar
It's my old one I fabbed up a long time ago. $20 and u can just have it.
Old 06-29-16, 09:57 PM
  #476
estomax
estomax's Avatar
looking good halon, since my bellhousing is already shaved I might go your route if I redo my setup to avoid buying a new transmission
keep those updates coming!
Old 06-30-16, 07:26 AM
  #477
LoveSCs
LoveSCs's Avatar
Looking good! Can't wait to see it with the bellhousing on and back in the car!
Old 06-30-16, 08:13 AM
  #478
Halon
Halon's Avatar
Slave installed, and bell housing on. Everything has fit perfectly. So far, extremely impressed with this adapter from Collins. You can tell he's taken things to a new level of quality, product seems much more matured!
My new fitting for the shifter is done as well. I'm going to test fit it tonight, hopefully it ends up fitting well.
Attached Thumbnails CD009 350Z 6spd On 1JZ SC400-20160629_210532.jpg   CD009 350Z 6spd On 1JZ SC400-20160629_172202.jpg
Old 06-30-16, 12:43 PM
  #479
Halon
Halon's Avatar
Version 3 of the fitting done. This fits extremely nice, don't see any reason to change the design of it at this point. It works with 19-20mm worth of washers/spacers.
I just still feel like the left to right movement is so close. I'm going to run it and see if I get used to it, but man just seems like miss-shifts waiting to happen.
Sorry for the picture quality. I did this quick over lunch, and just snapped pics with my phone quick. Some of em turned out really blurry.
Attached Thumbnails CD009 350Z 6spd On 1JZ SC400-20160630_121828.jpg   CD009 350Z 6spd On 1JZ SC400-20160630_121841.jpg   CD009 350Z 6spd On 1JZ SC400-20160630_121849.jpg   CD009 350Z 6spd On 1JZ SC400-20160630_123821.jpg   CD009 350Z 6spd On 1JZ SC400-20160630_123831.jpg
Old 06-30-16, 01:24 PM
  #480
Ali SC3
Ali SC3's Avatar
Fantastic, hopefully you can get used to it, when I came up with that design I was just thinking about getting it to 32" not how well it shifts =(
Quick Reply: CD009 350Z 6spd On 1JZ SC400
