8052JZ's NA-T Build
Old Feb 10, 2014 | 03:16 PM
  #511
8052JZ's Avatar
8052JZ
Originally Posted by jwin
I have my 4 inch tucked as much as possible and I'm at little to no gap on Tt wheels. It's pretty freaking low. I'm running 600/325 as well. It rides really well. It's the perfect medium between too stiff and too soft.
Awesome I cant wait to get my set on there. I should be finished with exhaust tonight than ill be starting on the coil overs.
Old Feb 11, 2014 | 08:48 AM
  #512
8052JZ's Avatar
8052JZ
Exhaust mounts are made and mounted. Just need to make same tips. I ran out of material so that will have to wait until some 4" piping comes in. I wasn't able to get any good pics of it mounted but made a short sound clip video let me know what you all think. 4" all the way back to dual Vibrant aluminum race mufflers. I will get pics during the day of the hole setup.
It stalled out after I gave it some gas lol of coarse the car isn't dialed in yet but will be very soon
Old Feb 13, 2014 | 08:00 AM
  #513
8052JZ's Avatar
8052JZ
As promised, a shot of the exhaust mounted up. Next post will be on how i put together the gixxer drew setup together.
Old Feb 13, 2014 | 08:21 AM
  #514
8052JZ's Avatar
8052JZ
Default Gixxer Drew coilover assembly 600/325 springs rates
First things first, get all the parts together for one coil to make things organized.
Make Sure the C clip is on the upper most ring groove on shocks before anything. Than start to cut the coil sleeves. Turned out to be exactly 2" from the "Sharp edge" side. Mark, cut and clean up the edges.
After being cut, slide them over the shock with the perch on. Than install the plate that goes on top of the shock provided with the shocks. Now, no one on SF seemed to figure out what dust boot to use. So I searched around and some have used the boot from a power steering rack. Went to the auto parts store and asked what they had in stocked and grabbed them. Turned out to fit perfectly!! Hard part was stretching them over the shock and dust plate thing. Wasn't to bad after figuring it out.
Part number for the one is MasterPro brand Part number K9863
and should have something like this. I used metal zip ties at the bottem to make sure they dont move around.
Now slide the spring in. Put the spacer on provided with the shock on top. Press the bushing into the upper springs seat and set it onto the spring. put the top hat on and bolt it on.
And now your done! repeat for the other three and your set!
and whats left over
Old Feb 13, 2014 | 08:50 PM
  #515
gdoutlex's Avatar
gdoutlex
quick question, whats holding the sleeves onto the shocks?
Old Feb 13, 2014 | 11:15 PM
  #516
jwin's Avatar
jwin
The sleeve is tapered on the inside and the shock has a little groove in it as well so just the weight of the car will hold the sleeve in there if my memory is correct.
Old Feb 15, 2014 | 09:41 PM
  #517
8052JZ's Avatar
8052JZ
^^^^ that's exactly right...
Old Feb 16, 2014 | 05:33 AM
  #518
gerrb's Avatar
gerrb
Super Moderator
Richard , what hasn't been replaced on this car ? Looks to me the only thing original on this car is the shell itself .
Hey , how do you adjust those gixxer coilovers on the fly ... do you use a spanner ?, just wondering ... I am still on the fence about my suspensions till I have my real wheel and tire setups on my SCs.
Old Feb 17, 2014 | 07:18 AM
  #519
jwin's Avatar
jwin
Gerb - you would need spanner wrenches to adjust the height. Anything over the 600/325 spring rate would require a revalve from bilstein.
Old Feb 17, 2014 | 07:47 AM
  #520
gerrb's Avatar
gerrb
Super Moderator
thanks ... I didn't see any grooves on there that is why I was wondering how the spanner will hold on and rotate it. With the weight of the car, that thing will be tough to rotate without a good tool.
Old Feb 17, 2014 | 08:47 AM
  #521
8052JZ's Avatar
8052JZ
Gerb, thanks almost everything is replaced lol can't wait to see how this car will handle on the streets. After tune an all, tax return is allowing me to get 97+ body parts and maybe paint! This car is deff going to be the dream car for me as for handling and power.
Like Jwin said you can use a spaner wrench. There is a groove on the spring seat and a align key bolt that you tighten so the seat will don't move after adjustment.
Old Feb 18, 2014 | 08:56 AM
  #522
8052JZ's Avatar
8052JZ
New coils or on as of last night. Few more things to button up and shes ready to get off those damn jack stands. Than I can start messing with the tune so I can finally drive this thing.
Oh and did some dishes over the weekend Cleaned up the used rear ccw set so they can be reassembled. I decided to to get the lips re-polished. Later on down the road I will probably get them chromed like Shane did. But for now this will do.
lips and catch can that need to be picked up from the polisher.
Old Feb 18, 2014 | 10:28 AM
  #523
Freefallin's Avatar
Freefallin
Cant wait to see the wheels. Nice work!
Old Feb 18, 2014 | 01:21 PM
  #524
8052JZ's Avatar
8052JZ
Thank you sir! I will be ordering R888s in the next week or so and get those puppies mounted..
Old Feb 18, 2014 | 01:48 PM
  #525
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
that is awesome another good way to use the dishwasher. I admit I also thought those sleeves were just held on by magic, good to know there is a taper.
