Build Threads Details on Club Lexus 2IS owner vehicles
GFM slow and steady "build"
Old May 5, 2013 | 11:06 AM
  #136
euroimage's Avatar
euroimage
Originally Posted by Stainless9
Those are nice wheels man. Mind sharing the specs? I need tires soon, did u get a good deal on the ones you picked up? Tires for 19s cost soo much
The wheels are 3 piece Wald's which were in decent shape at a steal of a price. I didn't refinish them before tossing them on, plan on getting wider lips down the line. I paid less for real wheels and tires than most pay for their reps or one piece wheels def worth the extra $300 IMO. Also didn't cheap out on tires and bought something good, have seen too many people running off brand tires that come from horrible molds and are actually oval and never balance out
Specs are 19x9 et 32 19x10 et37 215/35 235/35 rears barely clear after the shaving and doesn't rub at all. Fronts will be coming down more tomorrow though
Old May 6, 2013 | 06:18 AM
  #137
ShawnD's Avatar
ShawnD
The new wheels really set the car off! Nice work!
Old May 6, 2013 | 09:58 AM
  #138
IS350AWD's Avatar
IS350AWD
Forgive me if this was in the post somewhere, but I couldn't find it. How did you get the NAV hack installed and what was the part you showed in the picture?
Also, which parts for the stainless pedals? Easy to install?
Nice ride!!
Old May 6, 2013 | 10:41 AM
  #139
euroimage's Avatar
euroimage
Thanks sir
Nice ride!!
The nav hack was just to enable rear camera while driving, there is a thread on here with the detailed info, the picture was of the rocker switch to turn it on or off.
You can buy the pedals from Sewell, straight forward install and they have a video of how to install them in their site
Old May 6, 2013 | 10:46 AM
  #140
euroimage's Avatar
euroimage
In some other news, had issues with the tpms adapters leaking, so back on stock wheels until my friend has some downtime at work. Annoying but it is what it is.
Had time to paint the plugs I used in the bumper. Please excuse the bugs, just washed the car Friday too
Paint matches pretty darn well and is def better than the screws until I get some body work done. Excellent temp solution.
Going to start pulling the pillars today in prep for the headliner swap tomorrow. Ill be sure to bring out my actual camera and snap pics of the process since I know there is little to no helpful info on swapping headliners
Old May 6, 2013 | 11:39 AM
  #141
Stainless9's Avatar
Stainless9
where did you get the plugs?
Old May 6, 2013 | 11:57 AM
  #142
euroimage's Avatar
euroimage
Home Depot
Old May 6, 2013 | 01:24 PM
  #143
euroimage's Avatar
euroimage
Ups showed up today with this
Most people say it won't do much but that's ok, one more thing to drag on bumps and toss sparks haha.
Old May 7, 2013 | 09:31 AM
  #144
euroimage's Avatar
euroimage
So here is the first part of the headliner swap. Ill probably rewrite this and post it more as a diy later.
First a pillars;
pry away from the body as far as you can
use a needle nose pillars to twist the black plastic to release the pillar
there is one tab at the bottom connected to the lower trim that will need to be released and then the pillar is free
b pillars:
remove the front and rear scuff plates
remove lower b pillar plastic trim
remove lower seatbelt bolt cover and undo bolt. unclip wiring
remove two screws on lower b pillar
pry out and pull down, thread seatbelt thru the opening
c pillar:
pry and pull away from the body, there is a tab holding it to the lower trim plastic that needs to be released
Lower trim that needs to be released
Visors:
visor holder:
twist 90* and gently pull out (yes i already had the black ones in)
visor:
remove cover (prys off)
undo two screws and visor will just pull out
I will add more as soon as I finish. the pillars took maybe 15 mins to remove. once my friend gets here it will also be easier to snap pics
Old May 7, 2013 | 10:16 AM
  #145
euroimage's Avatar
euroimage
Old May 7, 2013 | 11:12 AM
  #146
Stainless9's Avatar
Stainless9
i remember doing this on my old car, told myself id never do it again lol. easy but tedious
Old May 7, 2013 | 02:46 PM
  #147
euroimage's Avatar
euroimage
ive done so many vw headliners its not even funny haha.
took us about 2.5hrs honestly not bad at all for our first times doing a 2is headliner. results are well worth the time/money and effort.
Old May 7, 2013 | 03:02 PM
  #148
euroimage's Avatar
euroimage
continued:
remove the upper console with the 2 screws and pull down
remove handles by prying out the plastic "plug" and remove metal clips
remove rear upper lights (pull to remove, didnt take pics)
remove coat hangers (one screw)
Then pull down headliner carefully. there are 2 clips in the very back, a handful of clips along the side, and velcro right behind the sunroof
Next you need to drop down the back of the sunroof to be able to remove the sunshade
these bolts will need to be removed:
Once you are able to drop it down far enough to get a screw driver in there, remove the end of the rail that goes into the drain
slide out the original sunshade and install the new one
then the headliner itself
removing a front seat makes installing the headliner MUCH easier
make sure everything lines up properly, the front of the headliner slips over a lip on the sunroof the rest clips up in place.
then add back all the pillars and visors etc. then sit back and enjoy your new headliner
yes i still need to dye the upper consoles
Old May 7, 2013 | 03:03 PM
  #149
euroimage's Avatar
euroimage
and also had time to toss on the roof spoiler
Old May 7, 2013 | 05:45 PM
  #150
RVCAis250's Avatar
RVCAis250
Where'd you get a black headliner?
