"Biturbo 2JZ swapped' Soarer Build Thread"
Old Jun 1, 2012 | 09:26 PM
  #91
97-SC300's Avatar
97-SC300
hers my build thread...
https://www.clublexus.com/forums/sc-...s-of-pics.html
Old Oct 1, 2012 | 06:49 PM
  #92
biturbo632's Avatar
biturbo632
Well.. I've got to do an summer update since a lot of little thing changed!
The main thing was to drive the car and have the bug and problems to come out.
Well I got a issue about a bad tentionner pulley for the timingbelt, changed that!
Since then, the car is going good, very nicely.. well.. too nicely. Let's talk about that later!
First up, I installed an instinctor in the car, easy access, since now that I have a swap, we never know what can occur! We are never too safe!
by https://www.flickr.com/photos/153934546@N06/, sur Flickr
Next on the list of this summer, since I bought a set of Work VS-XX last year, but then I broke the engine, It's time to rebuilt them to news!
As they were:
Front 18x8.5 +45
Rear 18x9.5 +39
I found that the rear one fit the front.. well.. almost perfectly! So I tought, why not put the front center on the rear barrels, and buy news 4inches rear lips, to mount with the front inner barrel to make some 10.5 in the rear? That's what I've done!
So new setup (offset is an approximative)
Front 18x9.5 +32 mount with 245-40
Rear 18x10.5 +26 mount with 275-35
So first I recieved the 4inches rear lips, brand news from Work USA (since work canada didn't answer me back...?)
Desassemble them.
Dirty bi***es! Got to clean those! I've got an hard them getting those cleaned!
Before and after pics!
I discovered the 4 wheels centers have already been repainted... what a mess.. got an 13 hours job mostly by hand to get those sand correctly! Paint was chipping everywhere!!
"work station"
The center after time and pain, finally prep for paint!
The "paintboot setup"
Let's get those 3pieces back together!
Test fitted'em! Seems legit!
Get them mount with tires, and well.. have to push the already rolled rear fender half an inch!
Final result!
Last edited by biturbo632; Feb 10, 2022 at 07:42 PM. Reason: picture aren't uploading anymore
Old Oct 1, 2012 | 07:33 PM
  #93
biturbo632's Avatar
biturbo632
Next up, back to my "problems" of my car going too nicely..
Here's the problem..
Jap 2JZ with jap ceramics turbo + intercooler + exhaust + custom downpipe = 20-21psi of boost... without any boost controller! Fun.. yet... but way too much for those ceramic turbos.. those a clean, very little shaft play sooo.. wanna keep them from destroying...Plus, It just keep getting the boostcut and I need a tune to get rid of that!
So I got to lower my boost to 16psi, because, as I have read on the internet and through people who experience ceramics turbo from 1jz or 2jz, 16psi is the "safe zone limit"... after what, It's at my own risk.
Problem is, the stock wastegate in the exhaust housing of the first turbo isn't enough big, even if I keep it open, It will lag a looooot but still boost 20-21psi in third gear or more. So...
Option 1: get myself a stock downpipe, as it didin't come with the engine... (I passed few hours building the one I have now so... not really an option!
Option 2: porting the stock wastegate in the exhaust housing to.. as big a possible!
Option 3: Get an aftermarket wastegate and get it installed on one of the two manifold... that are made in cast iron.. not the best material for welding! Plus.. there is not a lot of space to get something more there!
So... me and friend think about, modifying the option 1, by choking the exhaust to the original size, between the downpipe and the "cat"
We've done it, but it's very unstable. boost was between 17 and 20 psi, on hot temperature as we were in august.
So back the option 2.
Get the front turbo out (pain in the *** when the engine is not out! Managed to remove it in 2hours.
Here's the before pic, with a 2dollars piece. the stock size is 26mm.
Maximum size goal 33-34mm (as the wastegate "door" is 34mm
We've got it right and the door can close on two little place where I left a bore.
The result were good, but not enough. It now peak a 18psi. Unable to go more higher.. already I'm more safe, but as I wan't lower, we get back with the version 2 of the exhaust choke.. A cone from 3inches to 2.25 inches (stock size) mount from a flench put inside the exhuast just after the downpipe.
Now I'm boosting 16-17psi.. I can't go more.. And doesn't have any other idea! SO... I'll keep it that way!!
Next was my tow hook, since I used it once and it bent a little bit on the left side.
Reinforced it!
2x 3/8 inch steel bar, fully weld where it bent
After what I found the upper front grill for the 97-00 front bumper, thanks to Omar (2GSC300)
Recieved it, installed it, but found that anthracite with the chrome surround does really fits the car.
Got myself a can of plasti-dip from a rep of www.dipyourcar.com
And for the last, my buddy found me a Nardi steering wheel, + NRG short hub and NRG quick release.
This was the missing piece in my interior!!!
But now I found that my lower grey trim are hold and have a blue-green fade to them, so... maybe doing something with that soon!!!!
So that's it for now, I'm waiting for my waterpump from www.driftmotion.com because mine begin to loose collant from the clutch fan pulley...
Winter is coming again! 1 month and my car get back in the garage.
2012-2013 winter project:
- Getting 800cc injector (maybe the sard one, bolt on..) + Fuel regulator installed for the tune in 2013!
Goal: 375whp at 16-17psi
- installed my JL audio 10inch subwoofer in the stock lexus location and the amplifier and the capacitor in the trunk.
- Getting car ready for repair as I will respray the 2 side of the car (all my fenders have damage due to rolling/pushing and other things) + installing my 97-00 side skirt (DAMN those are really missing in the look of the car!)
- Get some tire and the car ready for the track season!!!
See you soon!
Last edited by biturbo632; Feb 10, 2022 at 07:46 PM. Reason: picture aren't uploading anymore
Old Oct 1, 2012 | 07:38 PM
  #94
lilSCsteve's Avatar
lilSCsteve
Wow, I can't believe I missed this thread! Believe it or not, I went through this entire thread-totally awesome!
Old Oct 1, 2012 | 07:45 PM
  #95
biturbo632's Avatar
biturbo632
Thanks!! It's very appreciated that you took the time! That's the reason why I do this!
Old Oct 2, 2012 | 10:04 AM
  #96
scoobySC3's Avatar
scoobySC3
Awesome build buddy, car is coming along and looking great too
Thanks,
Rick
Old Oct 2, 2012 | 10:35 AM
  #97
DoomLight's Avatar
DoomLight
good looks man.
you should get the side skirts and rear bumper.
still droolin over the hidden gauges behind the panel over the glovebox
Old Oct 2, 2012 | 07:53 PM
  #98
biturbo632's Avatar
biturbo632
Thanks,
Rick
Thanks!! So far so good!
Originally Posted by DoomLight
good looks man.
side skirt are in but not installed yet and for the rear lips, I'm waiting for the Rideskinz erebuni style rear lips! As I was going to made one myself with two lips from other car, I would better wait for this one!!
Thanks for the hidden gauge! if I would only know someone here with a LHD sc300-400, I would be able to do some and sell them!
Old Oct 3, 2012 | 06:06 PM
  #99
htakhar92's Avatar
htakhar92
damn biturbo ur soarer is making me jealous!!! haha nice work tho man, i wish i had half the skills as you, keep up the good work!! ur car inspired me to get off my lazy **** and go wash my car haha
Old Oct 4, 2012 | 08:17 PM
  #100
biturbo632's Avatar
biturbo632
Hahaha! It's good to know that I made you move!
Thanks for the comments! Everything is possible if you want to!!
Old Oct 5, 2012 | 07:39 AM
  #101
WAsc300's Avatar
WAsc300
Wow! Those hidden gauges have got to be one of the most unique upgrades I have seen on these boards. Nice swap, and good looking car. One question; how often did you tow your car? I felt like you were reenforcing the tow every couple of weeks. Great build though
Old Oct 5, 2012 | 08:37 AM
  #102
YeA 2jZ's Avatar
YeA 2jZ
I am so copying that gauge set up...........
Sorry lol
Old Oct 5, 2012 | 08:38 AM
  #103
biturbo632's Avatar
biturbo632
Thanks for for all comments!! The hidden gauges is definitively unique!!
And for the towing fact, I've got my car towed twice since I own it (june 2008)
The first time was september 2011, when I broke my engine.. I had my front lip install 3 week ago and the towing guy told my if he use his hook to put my car on the truck, that would break my lip!
I was like.. nooooooo! So because my motor was already destroy but rolling on 4 or 5 cyl... I put my car on the towing truck on power. That's why I installed a tow hook during winter!
The second time was in july 2012. My engine run off by itself 2 street away from my friend where I was going, by chance this is the friend with who I made the swap. He came to me with his car and a rope and we towed it to his house. When we turn 90 degre tight turn to get into his driveway, everything was fine until I see that the two hook has move to the left and need improvement, what I've done!
That's it
Old Oct 5, 2012 | 06:50 PM
  #104
thm8d's Avatar
thm8d
i love the guage set up..!
Old Oct 5, 2012 | 06:57 PM
  #105
bryan767's Avatar
bryan767
Yay for pics of tow hook!!
