Build Threads Details on Club Lexus SC owner vehicles
My 2jzgte swap
Old 12-28-11, 05:34 PM
  #166
Vwpride12
Vwpride12's Avatar
Originally Posted by 1992Lexus
Keep us posted on the results of the upcoming mods.
I will, I'm trying to decide if I should take it to the Dyno or just meet with the tuner and have it street tuned. I also have my eye on a set of usdm turbos witch I might try and swap at the same time. If that works out I'll definitely go back to see the gains.
Originally Posted by RX469
Subscribing to your swap...
thanks.
Old 12-29-11, 04:34 AM
  #167
stockhatch
stockhatch's Avatar
With your injectors and standalone, I would not bother with USDM twins. You won't really gain power so much as a little bit of reliability. Save that money for the inevitable transmission swap you will need
Old 12-29-11, 08:17 AM
  #168
Vwpride12
Vwpride12's Avatar
I would do it for the reliability. I might be able to get them cheeeeeaaaaapppppp/free! There in a customers basement collecting dust along with a exedy twin disk for a v160, which wouldn't be free.
Old 12-30-11, 06:26 AM
  #169
Vwpride12
Vwpride12's Avatar
Well my suspension settled after putting it on the other night and the front sat about a 1/2 inch higher than the rear. I cut 1 dead coil off of the front and brought it down about a 1/2 inch. I have never been one to cut springs but I had to do it. Ill probably upgrade to coilovers when these shocks blow out.
Old 12-30-11, 08:57 AM
  #170
stockhatch
stockhatch's Avatar
Looks great! What size tire are you running in the back?
Old 12-30-11, 09:28 AM
  #171
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
The drop looks good. Mo Better!!!
Old 12-30-11, 10:04 AM
  #172
MKIVS374
MKIVS374's Avatar
Very nice work love it
Old 12-30-11, 07:15 PM
  #173
Vwpride12
Vwpride12's Avatar
I think it's a 255, they were bald when I purchased them. I think I am going to run at least 275's when I replace them. What are you running?
Double thanks!
Old 12-30-11, 07:33 PM
  #174
stockhatch
stockhatch's Avatar
Yeah, I thought they looked a little small. You can run 275s or more back there, and it sounds like you will be needing them with all your goodies and plans
I'm running 285s and love the way they fit and hook. https://www.clublexus.com/forums/6604426-post112.html
Old 01-02-12, 07:52 AM
  #175
Vwpride12
Vwpride12's Avatar
looks good, Do you think a 295 would fit back there?
Old 01-02-12, 07:56 AM
  #176
stockhatch
stockhatch's Avatar
Depending on the brand, you might be able to. I would probably sitck with a 275 or 285 max because once the sidewall starts bulging, handling and traction will both start to be negatively affected. Also, I have never scrubbed, and I have unmodded fenders. Of course I am not dropped, so you may run into scrubbing issues if you put too much tire back there and you are not rolled.
Old 01-16-12, 01:23 AM
  #177
breed
breed's Avatar
stockhatch: how did this guy not need a restrictor ring?. And wait just a minute did he say he's running 19PSI?. I believe the recommended safe limit for JDM twins to at lease last is (17.4psi/1.2bar). "Overboost shuffle" LOL
Anyways, Vwpride12 keep up the good work bro. Go easy on those twins.
Originally Posted by Vwpride12
Just got back, it made 400. It Could have made more but ran out of fuel because of the injectors. I didn't need the "restricter plate". I drove it home in the rain but as soon as the turbos kick in it spins.
Old 01-16-12, 07:21 AM
  #178
Vwpride12
Vwpride12's Avatar
Thanks Breed
Got my injectors, rail, gauge, and fuel pressure regulator. Ill probably put them on next week after I get my new rear tires.
Old 01-24-12, 12:20 PM
  #179
breed
breed's Avatar
Any update?
Old 01-24-12, 02:33 PM
  #180
j23a45m
j23a45m's Avatar
very nice build, I can't wait to get the ball rolling on my end.
Quick Reply: My 2jzgte swap
