VVTI Soarer build
Well its got a base map on
At low boost we're making 400hp and 350 torques i'll post the dyno sheet up in a mo... when i can get my stupid scanner to work haha
here is a small video of me just giving it a tiny bit on the road nothing evil since it was wet and i've not driven the car in nearly a year
http://www.youtube.com/watch?v=o4TN2IhVdeI
Just thought i'd mention ... the speedo is mph not kph haha
Another note... This is with no VVTI. It was playing up at the high rpm's so were going to put it on at lower rpms then nock it off at about 5k as it does bring the boost in earlier with it on. just goes to rich up high
Just being doing the odd bits and bobs recently
Got the oil cooler installed
got the swirl pot and 10bar fuel pump installed ( still need mounted and tidying up
set up the traction control and launch control
video of launch control just for wet dreams
Been a while since i updated this. I've been way to busy but.. yeah i'll let this video speak for itself. Oh forgot to mention. The car made 460bhp in the end. Not the best but hopefully we can get more out of the new turbo (See below)
unfortunately the turbo died a few days after that video due to poor rebuild so i'm buying a gt35r at the end of this month
more updates then.
you can see the impeller wheel nut came off and the turbo ate it.
more updates then.you can see the impeller wheel nut came off and the turbo ate it.
a couple things...
if you wanna go 2j bottom end, you can get a vvti feed line from toyota from a 2jzge vvti, it's longer to accommodate the extra deck height, or your friend with the tig welder can just extend yours.
Also it looks like your ecu has no way of controlling the vvti from the looks of the dyno graph. Once you fitted the ecu it seems to be very similar to the non vvti graphs where torque peaks towards the end. IMO, that defeats the whole purpose of this engine. Super huge frowny face.
If I am correct about the vvti part no longer functioning, and if I understand the vvti purpose correctly, you will now have to worry about the extra .5 compression.
Thanks for all the good words
I'll find the pictures of the manifold and post them up shortly. It took some making but it's awesome.
The dyno graph from earlier was with no vvti enabled. That was just to test the car would run correctly which it did. When we mapped properly we enabled the vvti and that's when we got the 460 out of the car. I will see if i can get that graph and post it up
i didnt print it off at the time. I was to busy getting the car ready for the drag event that weekend haha.
The little corsa is amazing. It's my friend nicks and last i remember it was 580bhp the crazy little thing. here's a little video of it in action
I think i'll got 2jz bottom end once the 1j one goes. That's if it does
i'm hoping not at the minute since i'm paying £900 for a new turbo haha.
I'll find the pictures of the manifold and post them up shortly. It took some making but it's awesome. The dyno graph from earlier was with no vvti enabled. That was just to test the car would run correctly which it did. When we mapped properly we enabled the vvti and that's when we got the 460 out of the car. I will see if i can get that graph and post it up
i didnt print it off at the time. I was to busy getting the car ready for the drag event that weekend haha. The little corsa is amazing. It's my friend nicks and last i remember it was 580bhp the crazy little thing. here's a little video of it in action
Ah, so I was correct. Did mapping the cam timing bring the beautiful torque curve back? In for graphs! Does that ecu support vvti straight out of the box, or did you guys have the fun of having to set the range of the cam first through pwm outputs and such?
