Project Lex (92 Royal Jade SC300)
You would be third in line, but it's funny to see all these wingless SC's!
Keep up the good work B. The chisel trick is very cool.
Can't tell you how many frayed ends i've made with even the fastest cutoff wheel.
Got the trans mostly mounted up. Filled it up with some fluid just so I could do a test start-up on the car to see if it starts or leaks. She fired up pretty quick! Although towards the end it kind of sounds like a cylinder is miss firing or something, minor stuff hopefully. But overall pretty happy she fired right up and sounded good for the most part!
No idea yet what that noise is at the end of the video where it sounds like something fell onto the floor, lol.
Got some more body stuff. 97 skirts + door molding from RGW on here. 97 rear bumper and the little side extensions that go with it. Got the rear bumper because I want to try both the lip on my 92 bumper, and just the oem 97 bumper, and see which like I look better. Which ever I decide, I'll sell the other.
Since the car was misfiring, I went and got some new plugs. I have a dozen NGK's here, but didn't want to waste them / foul them out during this first few hundred miles of getting bugs worked out. So all the MKIII guys seem to have good luck with cheap Autolite 3923's, so I grabbed a set of those for dirt cheap to run for now until I get the bugs worked out. Took some pics to compare them to the NGK's in case anyone cares. They are very similar appearing.
Got the cross member and 240sx mount installed. Clutch is bled, feels nice and firm. Started up the car with the new plugs, runs decent but still misses a little bit. Will troubleshoot that some more this weekend I think.
That's about it for now. Hopefully the new driveshaft is here in the next week or so from Collins, and then it's all up to me at that point to get this thing running right. So close...
Spoiler experiment
OEM 1999 Accord coupe spoiler (brake light is still in the mail). Kind of gives you an idea of how it'll look, once I drill the holes it will obviouslly sit down flush on the trunk.
Basically I've been going for the spoiler look on this guys car. Unfortunately he has no idea what spoiler it is. So after searching and searching, I seriouslly think it's an OEM 99 accord coupe spoiler, so I got one from a junk yard for cheap, hence my experiment
It's a little different than the OEM 97+ SC300 one, similar, but different, and different enough that I wanted to try and find it rather than run the 97 SC300 one.
Installed the driveshaft from Collins today. FYI that it requires the use of a Drift Motion adapter piece like this:
http://store.driftmotion.com/static/...termk4gssc.php
Here's a pic of the driveshaft:
Car started up, it's still running like **** even with the new plugs installed. With the rear of the car jacked up, I just quickly verified the wheels turn forward in 1st gear, and backward in reverse. I then went to install the exhaust, and one of my V-Band clamps broke. So gotta find one of those now.
Also don't think I put up a pick of the 240sx clutch line I used to go from the stock hard line to the 350z slave. Worked out pretty nice, and was dirt cheap off egay.
Driveshaft is installed. Local diesel shop came through to repair my marmon exhaust clamp, so my exhaust is fully installed. Car is off jack stands, battery charged up. It starts up real nice, but it still runs like crap, kind of like a cylinder is missing. I replaced the plugs which didn't seem to really do much. So need to just finish troubleshooting that and hopefully it's nothing serious. Then take it for a drive around the block
Spoiler experiment
Sorry I haven't updated anything over here. Been pretty busy lately with other priorities. Basically I had the car somewhat running, and then the flywheel adapter came loose. So I've since pulled the tranny, applied more loctite to the bolts this time. I have the adapter, flywheel, and clutch installed again. Now I just need to get the tranny back in. I'm old and slow though, so don't hold your breath.
