My ´97 SC400
#166
Hy!
Today i removed both main converters both head shields from the manifolds removed, but the shield on the driver side is very difficult to remove out of the car.. any ideas?
The manifold on the passanger side is to 95% removed, only one nut goes not open The position is the last one in the upper line, near the EGR. VEry stupid place for a nut! any ideas??
Thanks!
Tom
Thanks!
Tom
#167
Hello!
Today was the day off the headers
My SC waiting of me
Here the bad nut
With a hammer and a chisel have i won!
OEM header removed
OEM header and gasket
IMF Header
studs for EGR from OEM header
its not easy to install on the passenger side. the flange is ok on the engine side, EGR 90% ok but the flange to the downpipe is not perfect position
ok... its not ok for me, to install it correct, i must modify the complete exhaust. On driver side, maybe remove the steering and the engine bushes and more.. not easy on this car! i installed the oem parts back and i sell the headers, too much for me, and i have not a professional garage to do all this.
But, i changed the sway bar bushings on front
look around
Oil pressure switch
many things
exhaust
header driver side
My SC waiting of me
Here the bad nut
OEM header removed
IMF Header
look around
Oil pressure switch
many things
exhaust
header driver side
#168
After the exhaust complete installed, i beginn to install the Rear Supra Sway Bar with PU Bushes
original mounting point
test
bruzzelbruzzel B)
painted and fixed
The rear of the car is much stiffer, but not too much, its drive very good, more control for slides
greets
test
bruzzelbruzzel B)
painted and fixed
greets
#170
HY!
Thanks lulu4545
Today, i recieved a Supra TT front sway bar from Germany
looks not much different to the original SC sway bar
left oem with the bushings, right the Supra TT
To change is not difficult, but i must modify the holder for the steering pipes modify (90° back) to have a little space between the sway bar and the pipes. To the oilfilter is ~1,5cm space, not much.
The first testdrive was good not so much different like the swap in the rear, but stiffer and the steering is better, more straighter and no contact feel from the sway bar to the oil filter
Next step are whiteline steering rack PU bushings, but the parcel will not come
greets
Boergsn
Thanks lulu4545
greets
Boergsn
#172
HY!
The headers are shipped to UK
i fitted the oem 16" wheels and tested the rubber
very funny with the LSD
The IS250 wheels sold and in the next weeks comes my new 18" rims from Japan
8" in front, 9" in rear. i will fit 235/40 on front and 255/40 on rear, i think, its ok
On october 21. i go on dyno with my SC400.
greets
Tom
greets
Tom
#175
Yes I know, but sometimes it helps to see something in your native tongue.
Never appreciated that until I lived overseas, but that's a story for another day.
She's looking very nice these days, and I know you must get a grin on the roads being one of only a few Asian cars, and definitely one of a very few SCs.
#179
HY!
Thanks
i will do my best
here my video from the dyno-run dyno-video in the rear you can hear, Mike with his IS300 Turbo for settings.
greets
Tom
Thanks
i will do my best
greets
Tom
