Sc300 W58 to cd001, HELP!!!!
Old Nov 17, 2023 | 08:08 PM
alphakill8's Avatar
alphakill8
6th Gear
Question Sc300 W58 to cd001, HELP!!!!
Hello I have a 1996 sc300 factory manual with a W58 in it I recently picked up a cd001 and plan on attaching the sequential shifter to it. I was wondering can I just use an adapter kit to fit the cd001 to the 2j and do I need to get a new slave cylinder? I know I need a cd001 clutch but for the slave do i need to do anything or can I just use the one I already have in my car? Also do I need a new drive shaft?
Also are there any adapter kits you guys recommend? and can I use the bell housing from my W58?
Old Nov 21, 2023 | 08:52 PM
Rcreegan's Avatar
Rcreegan
See my responses in bold
the slave many of these kits is a t56 I believe. You may need a new master cylinder depending on the clutch you go with .I know I need a cd001 clutch but for the slave do i need to do anything or can I just use the one I already have in my car? Slave does not move over, I think you’re calling the master cylinder the slave. The master attaches to the clutch pedal and the firewall, Slavs sits on the transmission. Also do I need a new drive shaft? Yes
Also are there any adapter kits you guys recommend? I would recommend the serial nine kit or the fisch racing. and can I use the bell housing from my W58? No , will not work
hope that helps you.
Old Nov 22, 2023 | 02:19 PM
alphakill8's Avatar
alphakill8
6th Gear
Which bell housing do I need?
Runvs
Oct 24, 2011 05:56 AM
soarinSC3
Oct 6, 2008 07:25 PM
