Ceramic Spray stuck in Chrome HELP!
So it looks like I missed a spot when wiping ceramic spray off after a wash. Does anyone know how I can get this off without scratching the chrome on the window?
I tried using a detail spray and degreaser and it did nothing. In the past, I used barkeepers friend and scratched the the chrome. What’s the best way to go about this? https://cimg8.ibsrv.net/gimg/www.clu...61a8d8ca0.jpeg |
You can try to level it off with the ceramic spray. If not you can try light polishing compound with a light to finishing pad try with hand polishing if that doesnt work you can whip out your polisher.
Or just wait it out. This stuff doesn't last forever, right?
Clay bar should do it. But as Julius said I'd try to level it out because that's probably easier...I'd respray re-apply and try to level it out by wiping. Also it would help to know which exact product you were using. Example: Griots doesn't do this, you can wipe it off at anytime even if you miss a spot like yours.
