Adam's Ceramic Spray Coating
Anyone here try it? If so,what are your thoughts on it? Would like to try it out since I'm not enthused about the traditional application process.
Not sure I believe the hype with all these ceramic sprays and ceramic hybrid sprays. It seems ludicrous that these would come anywhere close to an actual ceramic coating that costs several times as much (product only) and takes hours to apply. Getting a shine is relatively easy... for me, protection is where the value is.
However, I felt the same about Bead Maker, and although it's taken several months, I'm finally ordering a bottle to give it a try. Maybe the Ceramic Spray Coatings will live up to the hype... if so, I will eventually jump on the wagon with everyone else... let me know how it works for you. Edit: Just watched a couple of vids... seems like Adam's is different from the others, trying to market an actual coating in an easy to apply process. If this gets good reviews, I like easy... I will certainly add it to my inventory. |
I'd assume it's just a diluted version of the original. Their claim is 6-8 months protection. The ease of use is what attracted me to it.
Just coated the car with it a few weeks back. Totally not impressed. I followed instructions to the T and now it seems like it just evaporated off the finish. I corrected the paint prior to coating it and used their paint prep before application. I had some scratches that I didn't fully remove and the Coating just masked them. Couple weeks later the scratches reappear as if the coating disappeared. The car has mostly sat in the garage and hasn't been washed since coating. I'm calling them today for a refund or exchange for one of their other products.
My freind sent me a pic. of his hood after application after his first wash and the coating washed right off. No beading what so ever. He uses their traditional CC and says it works much better than the spray. of course the traditional coating is more labor intensive. As stated above, it's just a dilluted version of the original and not worth the $$. |
I doubt a spray ceramic coating is going to be anywhere near as durable as the traditional wipe on, wipe off ceramic coatings that come in small bottles. These ceramic coatings don't last more then 3 months in the bottles after you open them due to their formulas.
That’s disappointing to hear... well maybe not... it just means that I’ll be sticking with my regimen... polish with AIO Blackfire One Step, top with Sonax Polymer Net Shield, and maintain with Sonax Brilliant Shine Detailer (every 2-3 washes).
Quote:
Long live hype in a bottle! |
I've yet to be impressed by any of Adam's products...there are a number of tried and tested ceramic coatings that are very user-friendly and easy to apply by companies like CQuartz, Feynlab, GTechniq, etc. I'm currently running a test on the Mother's CMX spray coating on a new vehicle, and GTechniq Halo on my wrap/ppf vehicle, I'll post some updates here over the next couple months as I have more results.
I use some of his other products and are not bad. The H20 G&G and Ceramic Boost are outstanding products.
6-8 months is crap for a ceramic coating when top sealants like CarPro CQuartz UK will last 2yr if taken care of. Even if it is easier for a single app; if you are stuck having to wash and clean more often as well as 3-4 x as many reapplies in the same time as a single app of carpro CQ I do not see how that is either easier or less work / time. 2yr for every 6mth duty life = reapply 4x vs 1 app of CQuartz UK. Is it really more than 4x as fast and easy not to mention likely not close to as strong a coating new vs new.
Quote:
Quote:
Quote:
Agreed and still agree to make the response long enough to post. |
I called Adam's about the spray to complain. The bottle states it can be wiped off in 1-2 minutes. They stated that time frame is not long enough to wipe off. He suggested I leave it on 10-20 min. to where it gets a little tacky and then wipe it off. They need to change the instructions on the bottle. I tried it again yesterday and let it flash in that time frame and it seemed to work pretty good. I'm going to see if it holds up over time and if it doesn't, he said I could send it back no problem. This is the result using Glare Micro Polish with the C Spray over the top of it. I know that most people have never heard of Glare products.
I've been using it since 2014 and have always been happy with the results. I keep trying other polishes and always end up going back to the Glare. Not saying it's the best but it always works for me. https://cimg8.ibsrv.net/gimg/www.clu...0e98f5e7ed.jpg |
If I am going to apply a ceramic coating to my car it won't be a spray version. I have applied coating to a couple cars and the wipe on with a microfiber block or whatever you call them seems to spread it the best and maintain a even layer.
Might cost more but I believe you get what you pay for in this situation. |
| All times are GMT -7. The time now is 07:56 PM. |
