Automotive Care & Detailing Discussions on washing, waxing, polishing, detailing, cleaning and maintaining the beauty of your Lexus.
rubber seals maintenance
Old 05-03-18, 07:29 AM
GSteg
GSteg's Avatar
I have Shin Etsu and it's awesome! A little goes a VERY long way so apply as thin as possible.
Old 05-06-18, 11:04 PM
6od
6od's Avatar
I'm gonna guess that lot numbers don't matter very much and I'm fine to buy this one, right?
http://a.co/07UIMxn
Old 05-07-18, 02:35 AM
charley95
charley95's Avatar
I still think it’s overkill to buy a specialty product for w-strip IMO. I’ve had a tube of silicone di-electric grease that I got several years ago from the local auto parts chain. I maybe reapply once a year to treat my w-strip. It’s recommended by most manufacturers and is very cheap to purchase.
Old 05-09-18, 12:58 PM
TRD_Power
TRD_Power's Avatar
If you've got kids, I'd be more concerned with the Tide Pods in your laundry room than a little Shin Etsu grease on the rubber seals. The stuff is awesome and I'd highly recommend using it. 303 is great for interior parts, but it washes away pretty quickly when used on the exterior.
Old 05-09-18, 01:08 PM
Received 2,685 Likes on 2,273 Posts
If you have kids you should be much more concerned about bleach and rat poison.
Old 05-09-18, 08:51 PM
k20trick
k20trick's Avatar
guys as a precautionary measure please feel free to use something else or nothing at all. I can confirm that when touching the seals although it looks greasy nothing transfer over, probably of the material has absorbed and bonded to the rubber. And by the way, its hard to touch the seals unless you intentionally go for it while moving in and out of your car.
Old 05-09-18, 10:09 PM
Hudrock
Hudrock's Avatar
The kid stuff is ridiculous so not comment but already bought a tube and applied it to all the seals...works great thanks for tip.
Old 05-11-18, 08:52 PM
RichKeagy
RichKeagy's Avatar
I bought some Shin Etsu for my LC500. It's still pretty new so I can't say anything about it being able to protect weather seals.
However, it makes them look fantastic. Almost like new.
Old 05-12-18, 07:43 AM
k20trick
k20trick's Avatar
I thought I was nuts going to town on a 7 year old car, never thought seals on a new car would need this but glad to see you on board.
Old 05-16-18, 08:09 AM
ipstat
ipstat's Avatar
How exactly does one apply the honda shin etsu grease?
RichKeagy (05-16-18)
Old 05-16-18, 11:44 AM
RichKeagy
RichKeagy's Avatar
I squeeze out a small dab onto my right index (pointer) finger and apply directly to the weather seals.
There are probably injunctions against this technique (skin contact), but I'm not a pro and I only do this once or twice a year.
I wash my hands when finished. Then I walk a little taller in the knowledge that I keep my car (LC500) lookin' sharp.
ipstat (05-16-18)
Old 05-16-18, 12:13 PM
ipstat
ipstat's Avatar
So do you smear it on the whole seal internally and externally of the seal, not just the inside closer to the door frame?
RichKeagy (05-17-18)
Old 05-16-18, 08:18 PM
Hudrock
Hudrock's Avatar
I use Nitrile Gloves (you can buy a box cheap at Home Depot). Work a dab of grease in-between fingers and you can like pinch the seals and work the grease in on both sides. Wipe off excess with a towel.
ipstat (05-21-18)
Old 05-16-18, 09:04 PM
ipstat
ipstat's Avatar
Thank you. I plan on using those as I use them often to wash dishes. Pinching it is a good idea.
Old 05-17-18, 03:42 PM
RichKeagy
RichKeagy's Avatar
Ipstat: I apply a very thin coating to anything I can reach without disassembly. Be sure to wipe it down when done to remove excess.
You'll notice the grease around the side window edges where they touch the weather seals unless you wipe the excess off. I learned.
ipstat (05-18-18)
Bocatrip
03-14-19 08:49 AM
k20trick
IS F (2008-2014)
14
03-16-16 09:21 AM
Lavrishevo
12-26-15 11:20 PM
chewbone
06-05-05 08:37 PM
BA_GS400
03-17-05 06:17 PM
Quick Reply: rubber seals maintenance
