Full paint Correction and Ceramic pics.
Very brave of you to use the phone light, theres cheaper alternatives such as the led lightning on amazon or this kit:http://www.detailedimage.com/Scangri...SABEgKxc_D_BwE.
Once you use it, especially the sun match and the view for interiors, engine works, etc it really becomes a necessity.
Break2 (09-13-17)
There probably is, but right out of the box everythings ready for immediate use and it doesn't need to be used primarily to inspect paint, I found quite a few uses for it that it makes it a necessity in my arsenal. The iview comes in handy it almost becomes a necessity for working under the car, engine bay, and interiors especially. Also, the lightning takes up minimal space I can snap it on via the magnet and/or hook and it virtually space space. Lets not forget how portable the sun match is compared to lugging around 2 stands and heavy leds and the cord free use. Id rather invest in this rather than 5 sets of polishes, 3 different polishers, 10 different lsps because its something I will always have and need.
Auto Detailing Master
To each his own, but the average person can certainly find a very nice work light and portable flashlight for <$150 for general use and detailing use.
I agree that there is also no need for "5 sets of polishes, 3 different polishers, 10 different lsps" as well for the average DIYer/vehicle owner.
As I tell many people who express interest in getting into detailing, it can be as inexpensive or expensive as you want it to be. First couple years of working professionally on people's vehicles, I just used a Porter Cable 7424XP with various backing plates, M105 and M205 (mostly), polymer sealant, and some basic cleaners. Simple, inexpensive, and absolutely got the job done
Break2 (09-14-17)
Optimum Wash - Two bucket method
Used a leaf blower to dry ( I always do) and a quick waffled towel wipe down
Meguiars clay bar
Griots fast cream
Griots Fast finishing pad
Chemical Guys Orange Hex Pad
Porter Cable 7424XP Polisher
Gtechniq Panel wipe to get any polish residue off
Gtechniq Crystal Serum. Two coats.
Meguiars clay bar
Griots fast cream
FIY, most compounds with an orange foam pad will finish near LSP ready on harder metallic paints. Nothing special about fast correcting cream. That stuff is so oily and the working time is so long, it actually slows down the process. M100 corrects way better and cuts much faster.
I guess if he is not doing it for money, it's okay to just stop at orange/griout correcting cream, but in a professional environment where your reputation is on the line, I would NEVER not do a finishing stage. Lots of these products have oils that make the finish look perfect until the first wash which is when you will see some micromarrring/DA haze reappear. I feel safe with Primer Polish, 85rd, Essense, and M205 (on harder metallic paints) as a finishing step with a white finishing pad. Anything more aggressive and you're playing with fire.
FastFord (09-18-17)
Griot's BOSS Fast Correcting Cream was my go-to compound... I had tested it side-by-side against M101 on a couple of occasions, and each time FCC cut as well and finished better. In my product review article, I actually used a USB IS-F as a test vehicle...
In our opinion it was, and is, an outstanding compound, but the awesome thing about detailing is that there are TONS of outstanding products for every part of the detailing process. As the saying goes, "find something you like, and use it often". There is no right answer to what products you should use, it just depends on what you feel works best for you
FWIW, my top 3 most used compounds are:
Griot's Garage FCC
Meguiar's D300
Meguiar's M100
-Zach
Griot's Garage FCC
Meguiar's D300
Meguiar's M100
-Zach
FastFord (09-18-17)
I've read so many good reviews about it, so I'll be giving it another chance with a different pad combination.
We generally only ever used it with microfiber pads. We blow the pads out after every section with the Tornador Blow Gun (standard practice when using a microfiber pad with any product).
I use the pad brush and brush out the pad clean every two sections, also use a clean and cheap throwaway towel you can find at Costco and turn the machine with the pad on facing the towel and remove as much residue as possible.
In a perfect world, I would change out pads every time, but with the above method I was able to get through one car with only a few pads per car, i.e. 2-4 3" and 2-4 5".
Griots fast cream Griots Fast finishing pad Chemical Guys Orange Hex Pad
You said you used these products, not sure if you finished out with orange pad and fast correcting cream or you use finishing pad with fast correcting cream or maybe used the orange pad in some areas and finishing pad in others?
Not sure about the aggressiveness of 100, however using 105 on my paint it removed defects rather too quickly and needed a followup stage, at this point I felt like it was removing too much paint and gave fcc a shot. It was slower, but I felt like I was removing less paint because I wasn't obtaining 90%+ correction with a couple passes.
Regarding the first wash after each panel, I used eraser to give the compound less chance to bond and inspect the surface before moving on, prior to coating I gave it a 2nd eraser wipe to ensure the coating was bonding to a clean panel.
I hear alots of good stuff about the primer polish essence etc, but I wanted to keep the process simple by using individual products for the job i.e. one for cut, one for polish, then lsp.
That compound is not even that aggressive. I tried to like it, but it will NOT in any way replace my go to compound(s).
