California Water Blade
I actually saw one of these used on a dark green Lexus SC a couple weeks ago. It was pretty impressive. I'm not quite sold yet for my Black RX 300. Anyone use this?
Here's the Ad:
"The Original California Water Blade is NOT some ordinary squeegee with a fancy handle. Utilizing a unique molding process, the oversized blade is manufactured from one of the softest materials on the planet. It molds itself to almost any contour, and the exclusive T-Bar edge collects the water and sweeps it off in just one pass. The blade is so soft and pliable that it glides over any surface and has 15-times less friction than a terrycloth towel! You never have to worry about The Original California Water Blade scratching even the most delicate paint."
Here's the Ad:
GX and 2IS Moderator
I have 2
I use them on my black GS, and I think they really work. I usually wash the car twice to make sure I have not left any surface dirt (that would be bad using a CWB). I then wash off the blade as well, even though I try to store it in a Ziploc bag to keep it from getting all cruddy and dirty.
In theory I like the fact that I am not continuously rubbing with a terry towel to dry the car, but at a certain point you need to use a towel because the water blade doesn't always get all locations (I have a big and a small one) If it was doing damage to my paint I guess I would see straight lines up and down my hood as a result, but I don't I do see some swirls from the time the ****ING idiot detailer used a buffing wheel after I requested a hand wax only, but otherwise no problems. Kind of like the clay bar though...make sure the surface is clean, and the CWB is clean and you should be fine.
G35x - RWD/AWD goodness
You wern't in MI were you?
I have a dark green SC and I've used the CWB for a while now, it's great! I 2nd what Johnny Mo said, make sure your car and the blade are very clean before using. It has cut my towel usage way down.
The guys at autotopia don't like it becase you can drag dirt across your paint, but if both the blad and the car are clean it seems to be fine on the paint.
Overclocker
Overclocker
Re: I have 2
Originally posted by Johnny Mo
If it was doing damage to my paint I guess I would see straight lines up and down my hood as a result....
I used one all the time on my Black GS...no problems whatsoever...works great...saves time and towels...which saves sheep...or something...
I always wash mine before I use it though....
