Show Prep / Detailing Guide & Definitions
The Ultimate Guide to Show Prep and Detailing ( Thanks to Mr Spiffy )
What sets apart a mediocre show presence from a jaw-dropping display which wows all who see it? Lighting? Trophies? What makes a car really “pop”? It is true that it is all items working together, but the quality of the detailing is imperative. Having an impeccable car is a mod in and of itself. Prepare to embark on a journey which, upon completion, will leave you exhausted yet strangely content. Your car will beam in all aspects and heads will turn in marvel as you drive down the street. Welcome to the world of detailing. **This altogether will take quite a long time, so be sure to set apart 1 ½- 2 days for the whole job** Exterior: Products: Zaino Z1(or ZFX) Zaino Z2/Z3 Zaino Z5 Zaino Z6 Meguiars #2 Fine-cut Cleaner Meguiars #1 Medium-cut Cleaner Meguiars #7 Show Car Glaze Meguiars Show Car Wax (liquid) Meguiars Quick Detailer Meguiars SoftBuff Pads (cutting, polishing, and finishing) Claybar kit (Mothers, Meguiars,or Zaino) Dawn Dishwashing Liquid California Water Blade The Absorber Porter Cable 7424 buffer Step 1: It is important to begin with a clean slate when beginning a major paint overhaul. Begin by washing the car with Dawn dishwashing soap. I know this sounds like a detailing sin, but Dawn is perfect for stripping old buildup and leaving the paint clean and ready for the rest of the process. DO NOT make a habit of washing the car with Dawn, however. After washing the car, dry thoroughly with the California Water Blade and Absorber. Be careful to keep the blade clean as any particles can scratch the paint. Step 2: Now that the surface is fairly clean, it is time to further remove shine-blocking surface contaminants. A claybar is the best way to further remove harmful particles that inhibit shine and damage paint. It isn’t necessary or advised that you use one every time you clean your car, however I recommend use every 3-4 months depending on your location and the environments car is usually in. However, for show prep. purposes, a claybar is an excellent way to acquire an extra-deep shine. Set aside approximately 1 ½ hours for this step. It is a good idea to wear a pair of surgical gloves while using the claybar. They are helpful in keeping a good grip on it and blocking oils and other impurities from your hands. Fingerprints add oils to the clay and any small particles from dirty hands may cause scratches to the paint. Claybar kits usually come with a bottle of Quick Detailer, or a generic version of it, to use as lube. You can also use a mixture of car wash concentrate (Meguiars Gold Class or Zaino Z7) and water. Be sure to keep the surface wet with this while using the claybar. Spray a small area ( 1-2 sq. ft) and rub clay over paint until it feels smoother and there is less friction. You will be able to tell by touch. When the bottom of the clay begins to turn black, knead it into a ball and re-flatten. Continue like this with the rest of the car. Step 3: It is now time to re-wash the car. This time you will use a car wash concentrate. Re-washing will yet further remove contaminants loosened by the claybar and give a final squeaky-clean surface on which you will begin to repair the paint. Step 4: It’s time to begin buffing. First off is buffer choice. There are many options out there, from cheap Waxmaster units available at Wal Mart to professional rotary buffers. Unless you are a professional, DO NOT buy a rotary buffer. Instead, use a random orbital unit, or a “civilian” buffer. I do not advise buying a cheap unit, they will not last and do not provide the same results. They are also more likely to CAUSE additional damage. Instead, it is better to invest in a quality unit. The best I have found is the Porter Cable 7424. Doubling as a grinder/sander, this buffer is virtually “idiot-proof” and will give results unattainable by hand. It also has variable speeds, a useful feature in a buffer. With this unit, I recommend Meguiars Soft-Buff foam pads. The designated pad will be mentioned for each step. When removing scratches, you will always start with the lowest intensity products first and work your way up. In this case, you are going to begin with Meguiars #2 Fine-cut Cleaner (first with a normal polishing pad, then with a foam cutting pad) and, only if needed, #1 Medium-cut Cleaner (polishing pad, then foam cutting pad). Your buffer will also be set to 5000-5200 rpm during this step. Before you begin, take a look at the paint in direct sunlight. Sunlight is the best way to evaluate the extent of your paint damage. Just by knowing what you are dealing with may allow you to predetermine your pad choice. As a rule of thumb, sunlight shows big swirls and scratches, and fluorescent light shows smaller ones. Thus, it is a good idea to back the car in and out of the garage periodically to check your progress. To begin, you are going to spatter a SMALL amount of the cleaner onto a reasonable fraction of the car (i.e. the hood, then door panels, then rear section, etc.). You will continue to work it into the paint until you can no longer see it. To achieve optimum results, work from front to back on flat surfaces, and vertically on side panels. This will enhance the optical quality of your paint and make all angles more vibrant when you are finished. Continue like this until you have covered the whole car. Then mist and wipe the car with Quick Detailer. This will remove any dust that has collected and help enhance the shine. I recommend that you use quality, 100% cotton diaper rags to wipe the car. This step may require anywhere from one to four applications fo remove all the scratches. Step 4: Zaino vs. Meguiars From here you can take one of two different paths, Zaino or Meguiars. Both are excellent products and will yield amazing results, but I have found that Zaino polishes are optically superior to Meguiars. The major difference is longevity. The Zaino finish lasts longer than Meguiars, is easier to maintain, and isn’t greasy. The benefit of Meguiars, though, is price. Zaino polishes cost $12.99-$16.99 per 8oz. bottle while Meguiars #7 polish is $8.99 per 16oz. bottle. So you can obviously see the added expense. But, if you are after optimum results and price isn’t as much of an object, Zaino is the way to go. I will still, however, include Meguiars application instructions immediately under the Zaino instructions. Zaino: Zaino products work and are applied differently than Meguiars. The main difference is the longer curing time. Each coat of Zaino must cure for 12-24 hours. Thankfully, the makers of Zaino have developed a compound which drastically decreases curing time. ZFX, the compound in question, is mixed with either Z2, Z3, or Z5 and allows multiple coats to be applied in a day. Please note that use of ZFX compound takes away the need for Z1 Polish Lok. You will begin by applying Z5, a scratch-masking polish. If you plan on using a ZFX enhanced version of this polish, you will add 4-5 drops of ZFX to an ounce of polish. Apply this by hand with a Zaino polish applicator once again following the front to back and vertical technique mentioned earlier. Let this dry for 30 minutes. During this time you can work on detailing another aspect of the car. After Z5 has dried, you will remove it with a large, white, 100% cotton towel. Be sure not to skip little noticed, but still necessary areas such as door sills, trunk and hood lines, and the fuel door. After all, this is detailing. Don’t skip details! After completely removing the polish, mist and wipe the car with Z6 Gloss Enhancer. Although seemingly unnecessary, it really does help to deepen the overall shine. Depending on how many small scratches are left, you may want to repeat this process a few more times. With each application you will notice the scratches and swirls beginning to lessen, however there shouldn’t be many left after use of the paint cleaner. Now that your paint is close to perfect it is time to develop the shine. At this time your paint is looking pretty good and you may be tempted to stop, however your shine has only begun to show itself. It is time to begin with Z2 or Z3. If your paint is clear coated, you will continue with Z2, if not you will use Z3. Once again, if you are using ZFX enhanced versions of these products you will add 4-5 drops per ounce of polish. This polish will be applied exactly like Z5, following the front to back and vertical pattern. Let this too dry for 30 minutes before removing. Remove this too with a large, soft, 100% cotton towel. Also mist and wipe the car with Z6 Gloss Enhancer between coats. With each additional coat you will notice the shine becoming deeper and clearer. If you have a rich, darker color (like black or red) this step is a must and you may want to apply as many as four coats. Lighter colors (like white or silver) can usually get away with one to two coats. Z2 has a high quality sealer and needs not be topped with anything else. **Note: You can switch off between coats of Z2/Z3 and Z5, however you should always have Z2/Z3 as a final quote as they have higher optical quality.** Meguiars: If you decide to go the Meguiars route you will continue now with Meguiars #7 Show Car Glaze. This product isn’t actually a glaze, but rather a pure polish. Polishes have been known to be the real “character-builders” in the paint preparation process. Polishes bring out the deep, clear shine in your paint by feeding it with the oils it so desperately needs. Please note that you CAN use pure polish on new paint. It is non-abrasive and 100% safe. When using #7, take care not to apply too much at a time. When it comes to polish, less is always more. It is far better to apply several thin coats than gobbing on one thick coat. If you notice little specks starting to develop, don’t worry. You need only to keep working them out with your buffer. To begin application, you will spatter a few small dots of polish onto a fraction of the car as you did with the paint cleaner. With your buffer set to 5000-5200 rpm and using a polishing pad, work the polish into the paint until you can no longer see it. Then wipe down the excess with a clean, 100% cotton diaper rag. You will then mist and wipe the car with Quick Detailer. You will continue in this manner for a total of 2-3 coats. You will notice the shine becoming deeper and clearer with each application. **Note: Due to the greasy nature of the Meguiars products, you may wish to let the polish cure for an hour or more before continuing. If you are short on time, it is okay to continue immediately** Now that your paint is blemish-free (or pretty close), it is time to seal in all the oils you have just fed your paint. Wax is the sealer. Although there are many supporters of carnuba waxes, I prefer Meguiars Gold Class liquid wax. It is easier to apply and is more reflective. This is applied in the same manner as the paint cleaner and polish were, following the front to back and vertical pattern. With your buffer set to 5000-5200 rpm, you will use a polishing pad for this step. As before, work wax into paint until almost unnoticeable. Then, remove with a clean, 100% cotton diaper rag. Be sure to mist and wipe the car with Quick Detailer in between coats. I do not condone multiple coats of wax in rapid succession. This will actually KILL a little of your difficultly-earned shine. Instead, allow each coat of wax to cure for a few hours before apply additional coats. You will now go over the car with the finishing pad. This pad is good for removing any remaining wax residue and developing that little extra shine. Simply work your way around the car quickly with your buffer set to around 5800rpm. Congratulations! You have now finished bringing your paint up to “Spiffy” specifications. But don’t start resting yet. There is still the interior and other detailing necessities left to be done. Interior: Products: Meguiars #39 Heavy-Duty Vinyl Cleaner Meguiars #40 Vinyl & Rubber Cleaner/Conditioner Meguiars Heavy Duty Carpet Cleaner Meguiars Gold Class Leather Conditioner/ Armorall Leather Care Rain X Anti-Fog Wipes Can Vacuum w/ hose and 2 attachments Many people overlook the interior of their vehicle. After all, no one else see the inside. Why bother? You should bother because YOU spend your time inside the vehicle. The interior is your connection to the car and thus to the world you drive in. It is also a determining factor in the show arena, especially if interior mods are part of your presentation. This being said, let’s begin. Step 1: You should always start by “dejunking” the car. By this I mean removing everything that isn’t part of the car. It is far easier to detail the interior when there are no McDonald’s cups or Taco Bell wrappers in the way. Step 2: You now need to vacuum the interior thoroughly. I recommend a small, but powerful vacuum with a flexible hose and a slash-cut wand and a fuzzy attachment. While vacuuming, be sure to pay attention to details. Don’t overlook areas such as: under the seats, door handles, door pockets, glove boxes, cupholders, crevices in seats, and the trunk. It is the little things like this that set a detailed car apart. Step 3: As it is always advised to do your dirty work before your beautifying, it is now time to remove any stains that may be present in your carpets. Up until now I have attained good results using a Bissel Little Green, however, due to constant problems with the quality of Bissel’s machines I am currently looking for a new brand of machine. Stain removal is fairly straightforward. When using a deep cleaning machine, you will follow the same instructions as you would use in home. Pre-soak the surface with the cleaning solution and let it sit for 5-10 minutes. Now that the stain has had time to be released from the surface, you will now vacuum it out using your deep cleaning machine. It may be necessary to repeat this process with stubborn stains. In addition to the use of machinery, there are also several hand-applied stain removers designed especially for automotive use. Meguiars Heavy Duty Carpet & Interior Cleaner is a good product. I would recommend trying this before buying a deep cleaning machine. Also, a quick misting of Febreze can also help to remove any trapped smells. Step 4: **Note: This step is only necessary if you have stains or discoloration on your interior plastics.** To remove grime and thoroughly clean interior plastics, I recommend Meguiars #39 Heavy-duty Vinyl Cleaner. It will remove tough stains in plastics. Simply spray surface and wipe/scrub lightly with a double-sided sponge. Then dry as you go with a clean cloth or towel. Follow this with Meguiars #40 Vinyl & Rubber Cleaner/Conditioner applying as before. Be sure not to skip ash trays, cupholders, storage bins, or any little nook that your car may have. There is no excuse not to pay attention to detail! Step 5: You can’t forget the windows. The reason you are doing these next is that any of the products before would have messed them up, and cleaning the windows may mess up the following steps if they came first. For interior glass, I actually recommend Rain X Anti-Fog wipes. They are ammonia-free, and thus safe on interior tinting. They also do help prevent fogging. One wipe is good for all interior glass on an average car. You will first wipe down the glass thoroughly, being careful to get in deep cracks. Also, don’t forget to get the top portion of the window which often gets overlooked when the window is completely closed. Details! Next, buff out window with a clean, 100% cotton cloth or towel until glass is perfectly clear and the haze is gone. Step 6: . Now that all the ““ugly”” work is done, it is time to start beautifying your now sterile interior. Another common myth about car cleaning is that Armorall is a miracle liquid. It is actually one of the worst products to use on your interior, especially the dashboard. I recommend that you use Armorall only on wheel well plastics and on plastics in the engine bay. This being said, I would suggest that instead you would use a leather conditioner. Leather conditioners are also good for use on vinyl. The two products that I prefer and recommend most are Meguiars Gold Class Leather Conditioner and Armorall Leather Care. They both result in similar suppleness, with the exception that the Armorall product provides a slightly shinier appearance, which is why some prefer to use it on dark-colored leather. The Meguiars conditioner, however, provides slightly better moisturization. Choose a product based upon the criteria of your needs. Apply either of these products with a soft cloth, a little at a time, and rub into the surface until fully absorbed. Step 7: Now that all steps have been completed, do a look-through of the car, taking notice of anything you might have missed. Then, re-vacuum the carpet to remove any particles of cloth that might have come off during the leather conditioning process. Engine Bay: Products: Simple Green/Meguiars Extra All-purpose Cleaner/Degreaser Several plastic bags Meguiars Gold Class Vinyl/Rubber Protectant /Armorall A medium-sized paint brush 2-3 toothbrushes One of the most often forgotten and ignored aspects of detailing is the engine bay. It is, for most people, the least seen and of last importance. However, being key in the show arena, having a clean engine bay is essential. **Note: If your engine is exceptionably dirty, it may be necessary to take it to have it professionally steam cleaned to remove caked and burnt-on grime.** Step 1: Before any true detailing can be done, the metals of your engine may need to be degreased. For this, I recommend either Meguiars Extra All-purpose Cleaner or a high concentration of Simple Green. Both products do a great job of cutting grease. First, cover the alternator, ecu, battery, and ignition with plastic bags. Then, with a warm engine (not hot) spray on the degreaser and let it sit for 10-15 minutes. Scrub, if necessary, with a medium-sized paint brush or toothbrushes. Then, rinse with a slow stream of water. You may need to repeat this step. A paintbrush can actually be a helpful tool in cleaning the engine. Dry the engine bay with a few old rags. Step 2: It is now time to begin detailing the engine. Believe it or not, glass cleaner works well for shining up engine metals. If you have polished engine parts, Meguiars Gold Class All Metal Restorer is a good product. If you have chrome parts, you will want to clean them with Mothers Chrome Polish. Painted parts need only be misted and wiped with Quick Detailer. As for plastics and rubber hoses, either Armorall or Meguiars Gold Class Vinyl/ Rubber Protectant (Meguiars obviously being the superior product, but Armorall still get’s the job done). When working in the engine bay, be sure not to overlook details such as hoses, wiring, and turbo piping or intercoolers (if applicable). Also, look up. The underside of the hood is another commonly forgotten thing. Clean the lip of the hood with Quick Detailer, being careful to clean inside the hood latch and hinges. Once again, details! Wheels, Tires, and Other Details: Products: Meguiars #36 Professional Wheel Cleaner Meguiars Gold Class All Metal Restorer Meguiars Endurance High Gloss Tire Gel Meguiars Gold Class Vinyl/Rubber Protectant /Armorall Meguiars PlastX Meguiars Clear Plastic Detailer Mothers Chrome Polish Rain X Windshield Treatment Windex Wheels: Wheels are fairly easy to care for once you know a little more about them. Before beginning, try to learn whether or not your wheels are clear coated, polished, chrome, painted, etc. Knowing this will help in product selection. You will begin by spraying them with Meguiars #36 Professional Wheel Cleaner. It is a non-acidic product which quickly loosens road grime and brake dust. Be sure to get the brake rotors and calipers while you’re at it. After letting it sit for about 2 minutes, you will rinse the rim surface with a steady stream of water. A second application may be necessary. Now, if your wheels are polished or chrome you will polish them with Meguiars Gold Class All Metal Restorer or Mothers Chrome Polish respectively. For either product, apply with a soft, 100% cotton cloth or towel and allow to dry to a haze. Then, with a clean cloth or towel, wipe away residue to discover a highly reflective shine. If your wheels are clear coated or painted, you need only to dry them after use of #36. Tires: Provided that tires have already been washed (done while initially washing the car), you need only to dress them. I highly recommend Meguiars Endurance High Gloss. It is virtually waterproof, lasts longer than any other product I have used, and looks great. Simply apply a small dab to a sponge and wipe on. Misc: Wheel Wells: Wheel wells are entirely important. They are usually a way to tell if the person who cleaned the car cared about what he was doing. To clean them, first spray inside the wheel well liberally with Meguiars Extra or the aforementioned mixture of Simple Green. Allow to penetrate for a few minutes and rinse with a stream of water. Then dress with either Armorall or Meguiars Gold Class Vinyl/Rubber Protectant. This will leave the inside of the wheel well looking clean and dark black. Exterior Glass: Exterior glass is another easy, but still essential part of detailing. Begin by misting with Windex. Then buff away the haze with a clean cloth or towel. If you like, you can treat your windshield with Rain X. Doing this will cause water to bead up and keep your windshild looking good longer. Simply apply with a cloth or towel and allow to haze. When white, buff out with a new, clean cloth or towel. Headlight/ Taillight Lenses: It may also be a necessary to polish the lenses of the headlights and taillights. For this, I recommend Meguiars PlastX. It cleans and polishes clear plastic and acrylic surfaces and removes oxidation and road grime. To use, wipe lens with a clean cloth or towel and a small dab of product. Wipe for 30 seconds and leave to haze. Then, wipe clear with another part of the cloth. Follow this with Meguiars Clear Plastic Deailer. Apply this similarly, letting dry to a haze and buffing out with a clean cloth. This process will make your lenses shine resiliently. Mufflers/Intercoolers/Turbo Piping/Exhaust Tips: Mufflers, intercoolers, turbo piping, and exhaust tips are all fairly easy and similar to clean. The only exception being that turbo piping and intercoolers are harder to reach. Cleaning them is only a matter of applying Meguiars Gold Class All Metal Restorer and allowing to dry to a haze. Then remove with a clean cloth or towel to achieve a highly-reflective shine. Thus ends our detailing journey. By now, you have probably discovered that there is a lot more work involved in detailing than you may have originally thought. Personal detailing is also quite an investment. Some of you may not be ready, willing, or just don’t have the time to take up such a time-intensive endeavor. For you, finding a detailer may a more logical choice. Fortunately for you, you now have to tools to interview and decide on a detailer. Always talk to him/her first. Get to know their methods and techniques. Become familiar with their products. In doing so, you have a better idea of how your vehicle, one of your major investments in life, is being cared for. So, I hope you are now equipped to take the show scene by storm and look good doing it. And if not, you will at least look good. Congratulations, you are now “Spiffy”! By, Jeron Kerridge |
Definitions
By; Guitarman
This is a VERY basic list of detailing product/tool definitions. I will add more to it on a regular basis The amount of products and tools on the retail shelves can be intimidating and confusing for some, so let’s see if we can sort them out. I purposely decided to keep these definitions short and sweet, so as not to further complicate things. First, some DEFINITIONS; CLAY BARS; Clay removes “bonded contaminants”, the microscopic debris such as sap, paint overspray, bug remains, rail dust etc. that collects and sticks to your finish that washing can’t remove. If your paint feels rough to touch or ‘bumpy’ and not smooth as glass, you need to clay. PAINT CLEANERS. Paint cleaners are polishes with a high solvent content, as well as fine abrasives. The solvents in them do a good job of CHEMICALLY cleaning the paint. These are essentially an alternative to strict abrasive polishes. POLISH;Technically, a polish is any abrasive intended to solve a particular paint issue. Polishes fall into many varying grits, from very fine to heavy. Polishes (in the true sense ) contain NO wax or sealant. Here are some polish types; Glazes; A very fine polish with oils and fillers designed to heighten gloss and hide swirls. Water will rinse these away fast, so you’ll need to reapply after heavy rain or washing the car. Swirl Removers; Fine abrasives intended to level swirls . Every brand is of a slightly different, varying abrasiveness.Some swirl removers contain fillers, which hide swirls. Scratch Remover; Just another name for a medium to heavy grit abrasive polish that will “cut” paint enough to remove the scratch (if possible). Rubbing Compounds: A heavier grit polish with a larger particle size abrasive. Their goal is to quickly remove paint, but in doing so they often leave a haze (from the heavy particle size) which must be removed by a finer polish. Whenever you use a rubbing compound, you must follow it with a finer polish to achieve ultimate clarity in the paint. WET SANDPAPER. This is something generally used by professionals and takes a bit of practice. By using wet sandpaper, you can remove scratches, excessive orange peel or runs from a repaint, overspray, acid etchings etc. Sold in grits from extra fine (2000 and +) to coarse (180 grit). A "sanding block" is used in conjunction with wetsandpaper, sold in rubber or foam. They allow the paper to cut evenly while giving even pressure across the paper's surface. WAX; Automotive WAX is a combination of natural and synthetic ingredients, even if it says “100 % carnauba”. They just mean that they wax in it is all carnauba, not that carnauba is the only thing in the product. There are many synthetic chemicals that allow the carnauba to stay soft, allow it to “skin”, make it spreadable etc. Some products that are labeled “wax” also contain some polymer content. These are referred to as “hybrids” or a combination of natural and synthetic waxes. Wax bonds to the paint PHYSICALLY and that bond is easily broken with anything of a highly alkaline or acid base, as well as abrasives. POLYMER SEALANT; In essence-synthetic wax. No natural wax in the product. Polymers bond to the paint CHEMICALLY and are tougher to remove than wax based products, which is one reason they're more durable vs wax based. Abrasives will also remove polymer sealants, as will isopropyl alcohol. TOOLS; Rotary Buffer: Machine that spins in a strict circular motion, focusing friction and thus heat on one point. The heat focused on a central point allows to paint to be softened and the polish/compound to be broken down easy, resulting in fast paint removal. The choice of professionals, it can result in paint damage if used improperly. Random Orbit Polisher; This tool rotates in a concentric orbit, much like a sped up version of the human hand, and thus doesn’t generate enough heat on one point to damage paint. Ideal for applying liquid wax and fine abrasives, but not effective on severe paint issues. Buffing pads; Pads can be made of 1) natural lamb's wool 2). A combination of natural wool and synthetic materials, or 3). Synthetic foam. The natural wool and synthetic combination pads are called "blended" pads. Foam pads are made in various densities, with cellular "pores" and density defining how they cut paint. Wool pads don't generate as much heat as foam pads, but they are prone to swirling paint. Foam pads run hotter at a given RPM, but they are less prone to swirling.marrring, and come in densities to meet every need, i.e. Cutting, polishing, finishing etc. Spur; A spur is a metal tool that is used to remove compound and polish build up on a pad, Once the pad becomes loaded up with polish, it becomes less and less effective, so "spurring" the pad is necessary a few times during buffing. To do this, you hold the machine against your knee or lap, pad side down, and trigger the throttle button on and off while holding the spurring tool against the pad and moving the tool back and forth over the pad. This dislodges the caked up compound from the pad. This only works on wool type pads, not foam. A Phillips head screwdriver will substitute for a pad spurring tool in a pinch. On foam, you spur the pad by using a stiff nylon brush (a toothbrush will work) in the same way. Some common detailing issues TIRE BROWNING; Tire browning" is a normal condition engineered into tires. Tires contain compounds called "antiozonants" that are like micro-wax, and they are engineered to migrate out to the sidewall of the tire when flexing occurs. When they hit the air and moisture (humid climates see more browning for this reason), the compounds turn a brownish color. This is actually normal, but the degree of it will vary from tire manufacturer to manufacturer. It's better to cover it up with a product that makes the tires black than to strip it all off. You also shouldn't use a tire dressing with dimethyl silicone oils (like the old version of Armor-All) because they eat away the antiozoanants, resulting in graying tires and cracking. This whole process is referred to as "blooming", and if you clean the tire with a harsh cleaner, it can essentially force the tire additives to the surface, and the chemical reaction is shown by the brownish foam that forms on the tires when they're wet. It cleans so well it that when you repeat this cleaning scenario over and over, it depletes the antiozonants (there's only so much in there) and you wind up having none left, which in turn leads to the graying from the eventual depletion of the carbon black (called "competitive absorbers" ) that all manufacturers use to color their tires and protect from UV. Not to mention the good possibility of dried out rubber. Which is why you should use a protectant that contains anti-ozonants in it, to put back in what you take out from using harsh cleaners. A thread at Autopia detailing forum on topic; http://autopia.org/forums/showthread...=tire+browning In a nutshell, browning is ugly yes, but normal. Better to cover it with a quality tire dressing (preferably one that contains anti-ozonants) that makes the tire look blacker. You just but don't want to strip it with cleaners that contain hydroflouric or phosphoric acids (aka Bleech White) or strong alkaline cleaners like Simple Green etc. A good car wash soap and brush, plus a high end rubber protectant are the ticket.to get the longest life (and best appearance) from the tire. . |
:eek2: :eek2: :eek2: :eek2:
holy moly thats what I call a write up :thumbup: :thumbup: I wonder how much it would cost to have all this done :uh: |
That is more than exellent write up :thumbup: answers alot of questions :thumbup:
That was awesome. Thanks so much.
I'll post pictures later this spring. :) edit: okay, I didn't take pictutes...but I still wanted to post my feedback after using the guide for the exterior. Dish detergent followed by clay bar followed by regular car wash: This was really the only way to completely clean the car before using fine cut cleaner with the buffer. The clay bar did loosen additional dirt and contaminents that washing could not. PortCable buffer and Fine Cut Cleaner: Without the buffer, this step would have taken forever. The buffer is extremely easy to use, and the results were amazing. Almost all the scratches were gone. Some light swirls remained, which would probably have come out with another pass, but the next steps filled them in. I was being overly cautious on my first try. Polish: I had used swirl remover and wax before, but I didn't know about polish. The polish brought out a deep red shine that I'd never seen before. Just a few drops worked for large areas. The buffer just made it easier to apply. Wax: I always do this step but never before with a buffer. With a buffer, it's much easier to apply a very thing layer of wax so it won't reduce the shine created by the polish. Results: Spectacular. Cars rarely look this good after five years and 75k miles. My dad really couldn't believe it, staring intently at the reflected sunlight searching for the swirls that had vanished. The color is different, too: deeper, almost slippery, like an aquatic mamal. |
Steps to delete if new
If a car is brand new, what steps should be deleted?? Or another way to ask, at what step in the process can I start if the paint is only a month old???
Nice write-up but I noticed a couple things that are not quite right, IMHO.
You speak of using a Porter-Cable (PC) 7424 aka 7336. I agree this is the tool of choice and is almost idiot proof. But, then you speak of the 'rpm" the buffer should be spinning at and this buffer doesn't spin in rpm's. It oscillates so it has Oscillations per Minute (OPM's.) Much different than the rpm's of a rotary. I believe it would be more helpful to use the speed numbers on the PC switch here. For example for applying cleaners and polishes you would normally use speed settings of 4-5 and for applying pure polishes and wax you would set it to 2-3. Meguiar's Medium Cut and Fine Cut Cleaners are made for use with a rotary buffer. A much better pair of cleaner/polishes for use with the PC (7424/7336) polisher would be Meguiar's #80 Speed Glaze and #83 Dual Action Cleaner Polish. Also the #7 Show Car Glaze was made to be used with single stage paint. The equivalent product for clear coat paints is #81 Body Shop Professional Hand Polish. The latter is much easier to work with. Use of a cutting pad with the PC is not recommended as it can induce hazing and light scratching. I believe this is due the lack of heat generated by the PC causing the abrasives in the fine and medium cut cleaners to not break down properly. IMO, if you need to use a cutting pad you should be using it with a rotary and for most that means let a professional do it. It is easy to burn through your paint with a rotary and a cutting pad by non-pro. Meguiar's Gold Class is a fine product but I believe the better product is Meguiar's NXT Tech Wax. (a synthetic polymer) Wax choice is subjective however so there may be several opinions and they are all good. There is one other product I'd like to mention for interior detailing. That is Meguiars Quick Interior Detailer. This product leaves a new look to all interior vinyl. No extra sheen to cause glare, No streaking, just that new look. |
how bout if
1) 3m - compound 2) mezneno? or somthing like that finer grid comound and stage 3 right here is where im not sure about 3) either go with a (3m glaze) or (menzeno micro polish)? i dont believe the menzeno is actaully a polish its more of a glaze? but im not sure on this so thats why i wanna know what would u preffer *guitarmen* thanks any info appreciated 4) meguliars polish 5) meguliars gold class wax 6) meguliars qwick detailer ohh yea this is all off fresh paint thats been sitting to dry for mabe about 2 months nows? just wetsanded the car with 1500 and 2000 grid yesterday thanks for the input in advance for any help any info or experiance with meznenos products? and is hand glaze basically like polish? or would it make a differnce if u applied hand glaze before the polish step? im sorry but all these products give any names such as polish or glaze and i don't have much experiance with them so i dunno the grade level of the output i dont wanan polish my car and then use some compound over it lols~!! then it woulda been a hard day of work spend for nothing~! :D thanks in advance guys~!!! |
Samster, the hand glaze is a pure polish and not an abrasive polish. It kind of lays on the paint and deepens the gloss / shine, and will wash off fairly easily. This is NOT a step you want until you're all done with the paint. It's a final step before a wax.
When I'm at the stage you're at (just wetsanded) then i use the following: 3M Perfect - It III Rubbing Compound #05933 ( use a foam cutting pad) 3M Machine Glaze (this is NOT a true glaze however, but a mild abrasive polish) Use a polishing pad Meguiar's #9 Swirl Remover polish ( use a finishing pad) Of course I'm using a rotary buffer for all steps. With those products and steps I get black to a swirl free mirror finish, swirl free.. Hope this helps. The Menzerna company makes polishes that more or less mirror what 3M offers, and they are very good. I just can't get them (Menzerna) as easily on a local level as I can 3M. And when you need it, you often need it NOW. :D |
Hi,
I am new here. I am going to buy a Porter Cable 7336. What other stuff do I need? polishing pads, backing plate, ect. they sell it basic, with just the sander pad. Then, there are all sorts of options for polishing. I am going to do the Zaino treatment, and I know that I will be doing different polishes, glazes, compounds, and cleaners....then Zaino for the final touch. (my car is really dirty, and I also want to clean up the other cars in the family) What would you guys reccomend? flex backing plate, polishing pads, ect.. There are so many choices on ebay, so if you could help me sort it out, it would be great! Thanks, and this forum looks really informative .... Al |
http://cgi.ebay.com/ebaymotors/5-1-4...spagenameZWDVW
kinda asking my own questions..... do you guys use this backing plate? I guess it allows changing of polishing pad to be easier, right? al |
guitar man that is my problem i painted my car wet sanded with 1500-2000 then to 2500 grid wet, then i normally buff every fresh clearcoat with 3m rubbing compound and 3m perfect III glaze the white one for light color cars is what i used on my paint its 062 crystal pearl white and the clear was transtar set up i believe. after the wet sand, compound and glaze.
1) 3m compound 2) 3m machine glaze 3) this is where i used that mezenerna thing but i wasn't sure if i used it right but from lookin at the texture of the liquid polish itself i just judged it on the smoothness of it to use it lol One of them was a compound that i used over the 3m machine glaze and it look like it had no effect what so ever, and the one i used after that was a micro polish which showed a shine. 4) i used a polish either from mothers or meguliars it was a dark green liquid and it showed a deeper shine 5) i used meguilars classic car wax and then after this coat the paint felt very smooth and nice but i think the wax reduced the polish shine? 6) i've always used either qwik detailer or mothers showtime after the wax and the paint looks bling but it's not head turnin bling enough -=) mabe its just its white i've never yet seen awhite car that would reflect the sky, but damn i love clean minty white cars. I've done just simple and not spent so much time on my friends black cars and other dark color cars and it looks so amazing just to do a wet compounding with a cutting pad and then machine glaze and wax without the polish and everything esle. like a 2 hour job on their cars and it looks as if the paint looks 10x's better |
ohh yeah one more thing is after the winter months i've been bringin my car to car washes which i hate but i rather keep the salt of the paint then to wait it out and wash it myself. The car washes always leaves a very fine swirl mark do u think its needed for a compound + glazing job to remove?
or does polish normally cover it up? thanks! |
i use a similar backing plate like that with velcor cutting pads foam polishin pads from 3m works pretty great but u jsut gotta get use to placing the pad on in center
There's some great information in this thread. As with any "craft" there are multiple ways of acheiving great results.
While threads like this are always valuable, I always recommend dedicated detailing sites for folks who are really interested in learning about the topic. www.autopia.org is easy to recommend - excellent tutorials and lots of contributions from professional detailers. |
