mold-like spots on windshield
When it's dry, the glass is as transparent as new. However, when it rains or when I spray antifreeze, and use the wipers, I see these round mold-like spots on the windshield. It appears right after the wiper sweeps across the windshield, and it disapperas again as if it dries away. When the wiper sweeps across again, it appears again. It's extremely annoying especially when it's raining. It seems this happens to old cars only.
I miss the clear as crystal clean winshield of a new car. Any solution to getting rid of these 'molds'? |
I think I know what you're talking about. I used to get that kind of occurrence long time ago. I'd see these weird 'moldy' spots when it rains during the day, but after I applied some Quik Detailer spray on the windshield and thoroughly cleaned the rubber inserts of the wiper blades, the glass appears wax-like new and clean. You may want to do the same to your car and see what happens. I can't really explain the origin of those 'moldy' spots on your windshield. I'm just guessing, it could be spots where dried out tree sap or road tar used to be, etc...
Originally posted by lexusk8 I think I know what you're talking about. I used to get that kind of occurrence long time ago. I'd see these weird 'moldy' spots when it rains during the day, but after I applied some Quik Detailer spray on the windshield and thoroughly cleaned the rubber inserts of the wiper blades, the glass appears wax-like new and clean. You may want to do the same to your car and see what happens. I can't really explain the origin of those 'moldy' spots on your windshield. I'm just guessing, it could be spots where dried out tree sap or road tar used to be, etc... |
Originally posted by ChronoJ1 What's a Quick Detailer? Is that a brand name? Is it for glass only? BTW, I change my wiper every month. ( I bought 40 wiper refills) http://www.meguiars.com/store_meguia...roduct_a33.gif 40 wiper refills? That's crazy dude, you shouldn't have to change your wipers often. Check out this thread for recommended wiper change info. Hope this helps, Doug |
Thanks for the info. I'll try it out.
As far as the Wipers go... They don't last as long in the Michigan winter, especially with the frozen windshiled in the morning. So I change them every month during winter only. |
Re: mold-like spots on windshield
Originally posted by ChronoJ1 However, when it rains or when I spray antifreeze, and use the wipers, I see these round mold-like spots on the windshield. Antifreeze should only be used in the radiator.:p |
If all else fails, you could try claying your windshield. That works wonders.
Originally posted by ChronoJ1 Thanks for the info. I'll try it out. As far as the Wipers go... They don't last as long in the Michigan winter, especially with the frozen windshiled in the morning. So I change them every month during winter only. |
ChronoJ1, what you're seeing is very slight etching from mineral deposits in water that has sat on the glass and baked in with sunlight over time. They're not perceptible enough when the glass is dry, but water produces what is called a "definition of image" and the etches are magnified by it.
Eastwood sells a glass polishing kit; http://www.myclassiccar.com/NewProducts/glasspolishing/ That would probably solve that, since it's likely not too bad at this point. Once you can see them when the window is dry, they're usually too deep to remedy. Best of luck. |
Thanks for the info guys...
The wiper refills I use are Bosch micro edges. And about the 'antifreeze' comment .. :D I meant windshield wiper fluid, or whatever it's called. |
Originally posted by ChronoJ1 Thanks for the info guys... The wiper refills I use are Bosch micro edges. And about the 'antifreeze' comment .. :D I meant windshield wiper fluid, or whatever it's called. In the end, I now only exclusively use the OEM wiper inserts and/or OEM wiper assemblies (only had to buy these whole assemblies once due to very old age)--whether the car had been a Nissan, Honda, Acura, or Lexus. The OEMs last significantly longer than the aforementioned aftermarket brands, and despite their relatively higher cost is well worth it in the long run for durability, performance, and quality. Some things I say go w/ aftermarket, but this is the case where the OEM part is best. |
