Rx330 Brake Pads replacement
Old Jan 22, 2014 | 01:35 PM
  #166
mandyfig's Avatar
mandyfig
So far so good.
Old Feb 2, 2014 | 05:58 AM
  #167
lex_rx's Avatar
lex_rx
Nicely done mandyfig.
As for me, it was $,1800 to replace the two rear full brake components - rotors, etc.
I now believe that the culprit was a broken parking brake cables that my son and i have a habit of using. I didn't get this part replaced since the dealer wanted another $600. I'll have a look at this if I can DIY in the spring. I wedged a screw driver under the parking brake pedal so it can't engage again.
A bit scary anecdote is that on the day of the appointment, about two kilometers away from the dealer, brakes started to fade. I had to use four-way flashers and put the S-transmission into 2 or 3 to use engine braking for that 2-kM stretch of road. Whew!
So now rears should be good for another 10 years (except for the usual normal wear). For climates using road salt (and with new teenage drivers), I'd probably now recommend lubricating the pins annually and/or replacing the pins every few years.
Old Mar 6, 2014 | 06:29 PM
  #168
BBJdriver's Avatar
BBJdriver
Default 2009 rx350
Originally Posted by mandyfig
Rear components:
I just joined this forum and read this post. The torque specs you posted are for an RX330. Are these the same specs for the RX350? We have a 2009. Thanks for the information.
Old Mar 6, 2014 | 09:28 PM
  #169
RX330inFL's Avatar
RX330inFL
They are one and the same.
Old Mar 8, 2014 | 05:48 AM
  #170
BBJdriver's Avatar
BBJdriver
Thank you. I am replacing the brakes this weekend along wit brake flush.
Old Apr 16, 2014 | 09:10 AM
  #171
loco4diy's Avatar
loco4diy
Hello: I am new to this forum. I have been reading on how to replace the rear brakes.
I plan to replace the rear pads on my 2006 Rx 330. Is there anything different on the 2006 model. That I should be aware of?. I am tired of making the local Lexus dealer richer. I follow instructions to the letter.
Is there a link that tells me torque specs for bolts, grease points and materials needed for this job? Thanking everyone in advance.
Old Apr 16, 2014 | 09:26 AM
  #172
mandyfig's Avatar
mandyfig
Tons of knowledge on a couple of threads here, do your search. Good luck. Rears are easy.
Suggest you get your supplies at Sewell (we have a great discount) and then DIY.
Old Apr 22, 2014 | 01:19 PM
  #173
loco4diy's Avatar
loco4diy
I want to thank all the contributors to this DIY forum. I changed the oil and filter because of the instruction provided .
I broke 3 plastic clips, but that was my fault for not being careful. I will attempt front and rear brakes next. The OEM suppliers for this forum have a decent price for parts. I am grateful for everyone that has made this possible.
I hope to contribute soon.
Old Apr 22, 2014 | 01:31 PM
  #174
RX330inFL's Avatar
RX330inFL
Welcome to Club Lexus, loco4diy. Those plastic clips by now were probably a bit fragile with time and elements and even those of us who are used to how they work would probably have broken one or two by now. Nothing to worry about as they are easily replaced.
Old Apr 22, 2014 | 08:19 PM
  #175
rtbrjason's Avatar
rtbrjason
Lessons learned:
1. Caliper bolts have to be torqued correctly, 77 ft-lbs. Ask me how I know...
What happens if you don't torque these as per the specs you mentioned?
Old Apr 24, 2014 | 11:41 AM
  #176
loco4diy's Avatar
loco4diy
Thank you for the welcome. Do you know if video can be uploaded to this site?
Old Apr 24, 2014 | 12:38 PM
  #177
RX330inFL's Avatar
RX330inFL
I do not see that capability. Files are perhaps too big. You can at least post it on YouTube and point to it from here.
Old Apr 24, 2014 | 01:45 PM
  #178
kickin8's Avatar
kickin8
2IS/2RX/4RX
you can embed the video from youtube....
Old May 6, 2014 | 08:13 AM
  #179
loco4diy's Avatar
loco4diy
How did it go with brake replacement? Any complications?? Any lessons learned? I replaced the rear brakes this past weekend. Even though it took me most of the day I learned quite a bit. Thanks
Old May 6, 2014 | 05:25 PM
  #180
mandyfig's Avatar
mandyfig
If you do not torque correctly on the caliper bolts, you will apply uneven force to the caliper, leading to warping, will eventually exhibit increasing vibration when braking.
True test is while running at 60 mph, apply brakes suddenly, if you begin to shrudder/vibrate, there you go warped rotors!
The reason is I have been there. 77 ft-lbs, nothing more, nothing less. For Slider bolts, 25 ft-lbs.
