Instructions For The "JMcRaney Wind Noise Fix"
I was thinking about redoing the fix one more time because of recent comments on this thread and was thinking about the thickness of the triangle piece.
Thanks
Thanks
Thanks
Thanks
Thanks,
$30k and a $70k car look about the same. The LS430 is not mistaken for anything else on the road except maybe a 90's S Class.
Also the larger rims/ low profile tires on the LS460 compromise the smooth luxury ride. To me LEXUS has made a big mistake by trying to be a Japanese BMW. I buy LEXUS for an ultimate luxury ride not a full size sport sedan.
if I am curious to hear from other LS fans about what they think of this comparison and if there are more closet LS430 lovers coming out?
Or am I the only one that cares more about the car itself and less about having the newest technology.
Also, I would not compare a Lexus to a Nissan - it's like comparing a Mercedes to a Dodge
http://www.cars.com/lexus/rx-350/2013/expert-reviews/ has this comment: “While the interior of the RX can be incredibly quiet, filtering out an immense amount of road and engine noise, the extra-large side mirrors create more wind noise than expected.”
RX350 wind noise complaints have been common for several years. http://www.caradvice.com.au/26465/20...iew-road-test/ has this comment: “Disappointingly however, and contrary to claims from Lexus, the RX350 cabin is not as quiet as it could be. Wind noise from the large wing mirrors is evident through the side glass, as is tire noise on all but the smoothest of paved surfaces. Interestingly engine and exhaust noise is minimal showing improvements in some areas, but not others.”
A few of the owner reviews mention road/engine/wind noise too. However, many of the reviews have remarks about how notably quiet the RX350 is.
Even though several reviewers have attributed this problem to “large side mirrors” I find that view to be ridiculous. I assure you it has nothing to do with the mirrors.
MyLS460 is likely right, in his comment in Post #99 above, that the wind noise problem is related to the trim in the window corners, much like the trim defect that has affected many of the LS460s. I had a similar problem with my Toyota Sienna that I was able to fix with some sealant – it was so bad it was about to drive me crazy. Once a simple repair is done most of these noisy vehicles are transformed into exceptionally quiet vehicles.
Bettertown, your RX 350 can probably be repaired and ridded of the noise with a simple, inexpensive repair. However, it is unlikely that Lexus or your Lexus Dealer will help you with that. Since yours is a lease vehicle I am not sure what to suggest.
This problem that affects so many vehicles is not about air blowing through holes or air leaks. It is about the vehicle’s capability to isolate the inside from the noises that are occurring outside. This is a characteristic that can be easily quantified with an inexpensive sound meter.
I need to make a point here that I have made before but may have been missed by some: If you repair your trim then you should be sure to do both sides. The trim defect, although it can be unilateral (one sided), is usually bilateral (occurring on both sides). The important point is that if you have two sources of noise then getting rid of one will not likely produce noticeable results, so repairing one side and giving up because it didn’t improve things might be and probably is a mistake.
Here is an example of how noise in the presence of noise can be deceptive. Let’s say it is a quiet morning in the neighborhood with the background noise at about 40dB. And your neighbor has two identical lawnmowers. You get out your sound meter and turn it on and he starts his #1 mower – your sound meter reads 70dB. Then he starts his #2 mower – your sound meter now reads 73dB. Many people would not be able to tell you that a second mower was started by their perceptions of the sound. The sound pressure doubled when the second mower was started however many humans can’t distinguish an increase, or decrease, of 3dB. Typical human perceptions of sound is that sound doubles at about an increase of 10dB which is a 10X increase of sound pressure.
Keeping in mind the explanation above, let’s say that both trim pieces are detached and the noise measures 73dB. If we fix one of the defective trims then the noise drops to 70dB. Then when we fix the second defective trim the noise drops to 40db. This means that the sound pressure was reduced to 1/1000th of the sound pressure from one defective trim and the perception of the sound was reduced to 1/8th of the perceived sound of one defective trim.
Thanks.
I've been thinking of what to say that might be helpful.
I have not had a problem like that with my car and there have been only a few reports at CL about problems with window seals.
It seems unlikely that both front door window seals would be defective at the same time. And it is unlikely that there would be anything wrong with the parts that you couldn't feel or see from the outside.
Reports here and in other discussion have indicated that window seals and door seals were replaced and/or modified by dealers and individuals in attempts to stop the wind noise problem, with little or no improvement. We now know that many of the wind noise problem were related to the trim defect. It seems possible that the integrity of some of these seals may have been compromised because of improper reassembly. With that in mind I would look at the vehicle records to see if there is a note about that sort of repair.
Replacing the window seals is an expensive deal and with the uncertainty that it will help, or make things worse, you might want to try a few other things first.
It is not normal for your car to have noise at the top of the windows.
One area of concern with the trim repair is the spot under the upper rear corner of the trim, where the window seal meets the chrome piece. I expect every car is slightly different here because of fit and placement of the window seal, but there is often a deep crevice there. You should put the nozzle of your sealant tube into that area and fill it pretty good. If you don't understand what I am talking about I can post a picture.
One thing that may make my window runs different is that I had the windows replaced with the laminated windows, but not the seal kit because the vin# in the TSIB indicated I did not require it. Now I wonder, but I remember it is an expensive item to replace all the seals. Since I was hearing noise now at the top of the window, I was thinking to replace the top runs only.
I recently replaced the tires all the way around and the road noise is greatly reduced and overall the car is super quiet. I believe it to be true that it is so quiet that even the slightest wind noise is noticeable.
I may be wasting energy (and money) trying to eliminate all noise.
Thanks again.....
Thanks again.....
At any rate, there may not be a windnoise problem through the runner (drivers side) other than my brain still in the process of getting off the old noise problem (which is now fixed by the McRaney method)
, if any wind noise at all, it is difficult to quantify/pinpoint . . .I think you've made the right choice . . .
