lane change blinker
Old Jun 9, 2012 | 10:28 PM
Room4Tu's Avatar
Room4Tu
Went to the dealer today for my first 5000 mile service and had mine switched to 5 bursts while they were at it. I've got to admit 5 bursts seems just right. 3 bursts was just too short for me.
Old Jun 9, 2012 | 10:46 PM
onexcite's Avatar
onexcite
Originally Posted by gkcmilner
I will try to post the instructions tomorrow. It can be done yourself (doesn't need to be hooked up to the TIS computer like most LPS).
It's kind of a silly process, just a series of moving the wiper stalk. I changed mine to 5, but then went back to 3. (In the LS460 it's in the vehicle customization accessed in the nav screen.)
I'm looking forward to the DIY blinker change. Thanks ahead.
Old Jun 10, 2012 | 06:27 PM
gkcmilner's Avatar
gkcmilner
Attached are the instructions.
Sorry it's so late, but I just got back in town.
Old Jun 10, 2012 | 11:35 PM
onexcite's Avatar
onexcite
Thanks for the instruction.
I just don't get it why Lexus not built it to the menu setting just like the LS & LX.
Old Jun 11, 2012 | 02:06 AM
03LX470's Avatar
03LX470
LX has the blind spot monitor?
Old Jun 11, 2012 | 10:07 AM
LexusGSFGO's Avatar
LexusGSFGO
Great information. Thanks gkcmilner! It worked great. One question. What is the "same direction cancel function" supposed to do? Is this supposed to enable a function to cancel the normal turn signal by switching it in the same direction in addition to the opposite direction, which is the defaul? I could not get this part to work. Thanks again.
Old Jun 11, 2012 | 10:58 AM
ECL's Avatar
ECL
Does not work for me.
Old Jun 11, 2012 | 11:12 AM
LexusGSFGO's Avatar
LexusGSFGO
I had trouble at first too. Make sure in the first step you HOLD the position of the wiper in the off position while simultaneously hitting the ignition switch (twice if you are not starting the engine). Also note the difference between right/left "Lane change" and "turn".
Old Jun 11, 2012 | 11:51 AM
ECL's Avatar
ECL
I finally got it to work. My mistake was letting the wiper stalk return to the neutral position between maneuvers. Thanks!
Old Jun 11, 2012 | 12:34 PM
HUSKERnKS's Avatar
HUSKERnKS
Worked like a charm. Thanks.
Old Jun 11, 2012 | 01:16 PM
gkcmilner's Avatar
gkcmilner
What is the "same direction cancel function" supposed to do? Is this supposed to enable a function to cancel the normal turn signal by switching it in the same direction in addition to the opposite direction, which is the default?
You are correct. Instead of pushing the stalk half-way in the opposite direction (the default) to cancel the turn signal, you push it half-way in the same direction.
I haven't tried changing this since the default seems the most intuitive for me.
Old Jun 11, 2012 | 03:17 PM
drdigital1's Avatar
drdigital1
One more clarification: the procedure worked for me only when in step 5 I selected the desired setting on the wiper barrel switch before starting the entire procedure.
Old Jun 11, 2012 | 03:44 PM
ECL's Avatar
ECL
Not to hijack the thread, but is there a DIY way to make the key fob open the windows and sunroof?
Old Jun 11, 2012 | 05:59 PM
gkcmilner's Avatar
gkcmilner
Sorry, that will require a service tecnician to connect a Techstream computer to your car .
Old Jun 11, 2012 | 06:18 PM
varcity64's Avatar
varcity64
Thanks. I will give this a try.
