- Tires General Information and Specs
Important information to help you understand your Lexus
Browse all: Tires and Wheels Guide
LS 460/600 Wheel & Tire Information Details Thread
Wheel Brand: Savini
Wheel Model: Black Di Forza BM-3 (Concave)
Wheel Size Front: 22 x 9
Wheel Size Rear: 22 x 10.5
Wheel Finish: Machined Brushed w/ Black windows
Lip size front: N/A
Lip size rear: N/A
Lip finish: Chrome Stainless Steel
Offset Front: 35+
Offset Rear: 40+
Hub Bore size (if known): N/A
Hub Centric Rings Required?: Yes
Tire Size Front: 255/30/22
Tire Size Rear: 295/25/22
Tire Make/Model: Kumho Ecsta ASX KU21
Tire Air Pressure Preference: 42 PSI all around
Suspension: Stock (For now)
Fenders Rolled/Altered: No
Does the setup rub?: No
Pics Below:
Wheel Brand: Vossen
Wheel Model: VVS082
Wheel Size Front: 22x9.0
Wheel Size Rear: 22x10.5
Wheel Finish: Silver Matte
Lip size front (if applicable): 9.5
Lip size rear (if applicable): 10.5
Lip finish (if applicable): Polished
Offset Front: na
Offset Rear: na
Hub Bore size (if known): na
Hub Centric Rings Required? Y/N: N
Tire Size Front: 245/22/30
Tire Size Rear: 265/22/30
Tire Make/Model: Continental DWS
Tire Air Pressure Preference: 44
Suspension: Megan's Street Coilover
Fenders Rolled/Altered: Rolled
Attachment 239037
Wheel Brand: VOSSEN
Wheel Model: CV1
Wheel Size Rear:22x10.5
Wheel Finish: silver
Offset Front:?
Offset Rear:?
Hub Centric Rings Required? Y/N:Y
Tire Make/Model:Pirelli P Zero Nero
Tire Air Pressure Preference:42
Suspension:stock for now
Fenders Rolled/Altered:no
Does the setup rub?:a tiny but only on the rear right and only since I used the Pirellis. No rubbing with the Continental DWS
LS Year/Model: 2007 LS460L
Wheel Brand: Petrol
Wheel Model: vengeance
Wheel Size Front: 20x8.5
Offset Front:?
Offset Rear:?
Tire Size Front: 255/40/20
Tire Size Rear: 265/35/22
Tire Make/Model:Falken FK
Tire Air Pressure Preference:38
Suspension: will be lowered very soon
Does the setup rub?: not yet
LS Year/Model: 2008 SWB
Wheel Brand:Savini
Wheel Model: Black Di Forza Bm5
Wheel Size Front:22/9
Wheel Size Rear:22/10.5
Wheel Finish:brushed/black machined
Lip finish (if applicable):chrome
Offset Front:N/A
Offset Rear:N/A
Hub Bore size (if known):N/A
Tire Make/Model
irelli/pzero/neroTire Air Pressure Preference:42
Suspension:Stock
Fenders Rolled/Altered:No
Does the setup rub?:No
Pics Below:
Wheel Brand: Savini
[/B]Wheel Model:[/B] Black Di Forza BM-4
Wheel Finish: Black/Machined
Lip finish (if applicable): Chrome
Offset Front:
Offset Rear:
Tire Air Pressure Preference: 40 PSI all around
Suspension: Stock
Wheel Brand: GFG
Wheel Model: F-2
Wheel Size Front: 22X9
Wheel Finish: Machined silver
Lip size front (if applicable): N/A
Lip size rear (if applicable):N/A
Lip finish (if applicable): chrome
Offset Front: +35
Offset Rear: +35
Hub Bore size (if known):unk
Tire Size Front: 245/30/22
Tire Make/Model: Continental Extreme DWS
Suspension: Stock Air with Datasystem lowering module
Fenders Rolled/Altered: Rears shaved
Pics Below:
LS Year/Model: 2008 LS600hL (All Wheel Drive)
Wheel Brand: VOSSEN
Wheel Model: CV1
Wheel Finish: Silver Matte/Machined face
Lip finish (if applicable): Stainless Steel
Offset Front: et35 (et20 with 15mm Akata Spacer)
Offset Rear: et38 (et35 with 3mm Akata Spacer)
Hub Centric Rings Required? Y/N: Yes
Front and Rear Tires have exact same overall rolling diameter for AWD system compatibility
Suspension: Data Systems Electronic Lowering Module
Fenders Rolled/Altered: Stock
Does the setup rub?: Not as of yet while driving at level 3 of data controller. Last 3 pics are on Super Low Mode (controller level 9) which is for show only.
Secondary Setup below shows same wheels but with Akata Spacers added
Offset Front: +35 (with 15mm front spacer, new offset is appx 20mm)
Offset Rear: +38 (with 3mm rear spacer, new offset is appx 35mm)
LS Year/Model: 2007 LS460 SWB
Wheel Brand: WALD
Wheel Model: PORTOFINO
Wheel Finish: ALUMINUM (I BELIEVE)
Lip size front (if applicable): DUNNO
Lip size rear (if applicable): DUNNO
Lip finish (if applicable): ALUMINUM
Offset Front: DUNNO
Offset Rear: DUNNO
Tire Size Rear: 285/25/22
Tire Make/Model: Continental DWS FRONTS AND FALKENS 452 REAR
Tire Air Pressure Preference: 42 FRONT 40 REAR
Suspension: TANABE SPRINGS
Does the setup rub?: PROBABLY MILD RUBBING
Wheel Brand: VIP Modular
Wheel Model: VR01
Wheel Size Front: 22x9.5
Wheel Size Rear: 22x11
Wheel Finish: Silver polished
Lip size front (if applicable): ~3"
Lip size rear (if applicable): ~4"
Offset Front: no idea
Offset Rear: no idea
Hub Bore size (if known): 60.1mm
Hub Centric Rings Required? Y/N: no
Tire Make/Model: F-Contintal DWS, R- Toyo Proxes
Tire Air Pressure Preference: 40 psi all around
Suspension: Factory air suspension with lowering module
Fenders Rolled/Altered: Rear fenders shaved. Front fender plastic trims removed, fenders rolled
Does the setup rub?: No rubbing unless hitting very bad dips.
Wheel Brand: Lexani
Wheel Model: LSS-8
Wheel Finish: Black/Machined with Chrome Lip
Lip size front (if applicable): 3"
Lip size rear (if applicable): 5.5"
Offset Front: ET25
Offset Rear: ET30
Hub Bore size (if known): 74.1
Tire Make/Model: Nexen 3000
Suspension: Drop with Tanabe Spring on stock shocks
Does the setup rub?: No rub after the fender shave
Wheel Brand:Luxury Abstract
Wheel Model: Mador
Wheel Size Rear:22.10.5
Wheel Finish:
Offset Front:+25
Offset Rear:+25
Tire Make/Model: nitto
Suspension: stock air with data system controller, ride height at setting 5, pictures shown on 8
Fenders Rolled/Altered: rear fenders shaved
Does the setup rub?: when i roll on 5 it rubs on certain bumps not too bad.
Wheel Brand: Vossen
Wheel Model: VVS-084
Wheel Size Front: 20X9
Wheel Size Rear: 20X10.5
Wheel Finish: Silver Machined
Lip size front (if applicable): 1.75"
Lip size rear (if applicable): 2.75"
Lip finish (if applicable): Highly Machined Polished
Offset Front: 31mm
Offset Rear: 31mm
Hub Centric Rings Required? Yes
Tire Size Front: 245/40/R20
Tire Size Rear: 275/35/R20
Tire Make/Model: Faulken FK452
Tire Air Pressure Preference: 35psi
Suspension: stock
Wheel Brand: AGforged
Wheel Model: F440 concave spec.
Wheel Size Front: 22 x 10
Wheel Size Rear: 22 x 12
Wheel Finish: Black Chrome face and lips with Gold bolts
Lip size front (if applicable): 5in
Lip size rear (if applicable): 5in
Lip finish (if applicable): Black Chrome
Offset Front: ?mm
Offset Rear: ?mm
Hub Centric Rings Required no
Tire Size Front: 245/30 22
Tire Size Rear: 295/25 22
Tire Make/Model: Lionhart
Tire Air Pressure Preference: 50psi
Suspension: JIC coilovers and UAS bags with manual set up 2 channels
Fenders Rolled/Altered: front rolled rear shaved
Does the setup rub?: yes slightly on fender liner front and rear
Wheel Brand: Vossen
Wheel Model: N/A
Wheel Size Front:
Wheel Size Rear:
Wheel Finish:
Offset Front: 15
Offset Rear: 20
Tire Size Front: 265 30 22
Tire Size Rear: 295 25 22
Tire Make/Model: Continental <--- AWESOME GRIP
Fenders Rolled/Altered: YES
Does the setup rub?: YES. I took the wheels off after 2 weeks. The wheels were aggressive and I quickly found out that I had lost too much ride quality. They drove awesome in a straight line! I was unable to carry passenger, which is a trade i am unwilling to accept. Thus, I am back to stock after 14 days of the 22s.
Pics Below:
