JDM 2jzgte vvti swap GS300
Whats the details on your install? You have an 01, was an it an early or late year 01?
-Did your 01 have the Aristo/98-00 GS/Early 01 GS ecu harness or the Newest Style Late 01+ ecu harness?
-Are you using the GS or Aristo Engine ECU?
-Did you get the Aristo MAF with the swap?
-Are you using the GS or Aristo ABS/VSC/TRAC ECU??
Assuming you are using all ARISTO everything, you should check the VSS sensors for resistance.
If the sensors seem ok, and if you in fact had a New Style Late 01+ harness and had to cut/solder/repin/modify the harness wiring then I would check everything that was done there next.
This info is in another thread I posted it in, but I'll just post it here again. There are two VSS sensors on the Aristo trans, no 1 should be the front one, but you might as well pull them both and test them to see if the readings on both are in a similar range.
. If anybody have some pointers please feel free to drop in. One question tho, guys that didn't get you engines with the drive shaft, where did you order one from? eBay ain't got any. There's 2 on there both of which are for the 93-97 aristo. Would the first haft of those work? I'm not too clear as the s147 aristo didn't come with the vvti gte but they r all from Japan so the you're might match up not sure. Any inputs??
