DIY: 2nd Gen GS Fog Light Bulb Replacement
Old 06-10-10, 01:10 PM
skiz88
skiz88's Avatar
Default DIY: 2nd Gen GS Fog Light Bulb Replacement
Of all the DIYs on this board, I couldn't find one for a 2nd Gen GS Fog Light replacement. I found one for a 3rd Gen which states you have to go through the wheel well. This is not the case for the 2nd Gen which made this writeup a piece of cake.
STEP 1: GRAB A PHILLIPS SCREWDRIVER AND LOCATE THE TWO SCREWS HOLDING THE FOG LIGHT HOUSING.
Attached Thumbnails DIY: 2nd Gen GS Fog Light Bulb Replacement-dsc01328.jpg
FrankT (11-11-20)
Old 06-10-10, 01:11 PM
skiz88
skiz88's Avatar
Step 2: Remove the 2 screws
Attached Thumbnails DIY: 2nd Gen GS Fog Light Bulb Replacement-dsc01329.jpg
Old 06-10-10, 01:12 PM
skiz88
skiz88's Avatar
Step 3: Remove the fog light housing. It comes out at a slight angle. This picture is the front passenger side fog light.
Attached Thumbnails DIY: 2nd Gen GS Fog Light Bulb Replacement-dsc01330.jpg
Old 06-10-10, 01:14 PM
skiz88
skiz88's Avatar
STEP 4: Remove Fog Light and Twist out Bulb.
Here is the Fog Light Housing Removed - Very Simple.
Attached Thumbnails DIY: 2nd Gen GS Fog Light Bulb Replacement-dsc01331.jpg
Old 06-10-10, 01:16 PM
skiz88
skiz88's Avatar
Here is a pic with the bulb removed from the Fog Light Housing.
Attached Thumbnails DIY: 2nd Gen GS Fog Light Bulb Replacement-dsc01332.jpg
Old 06-10-10, 01:17 PM
skiz88
skiz88's Avatar
STEP 5: Press down on small plastic clip to remove bulb from Harness.
Attached Thumbnails DIY: 2nd Gen GS Fog Light Bulb Replacement-dsc01333.jpg
Old 06-10-10, 01:21 PM
skiz88
skiz88's Avatar
Last: Pop your new bulb into the harness, twist back into your Fog Light Housing and simply install and screw your housing back into place.
Note: There is a little tab on one side of the Fog Light housing that fits into a little slot in the plastic bumper space. The Fog Light has to go back in at the same angle you took it out so that it properly fits back into the slot.
This really takes only 5 minutes per side. Really simple! Hope this helps!
By the way - if you want to change your Side Markers or the Side Marker bulbs, you have very good access to them with your Fog Lights removed from the inside. There is a separate DIY on these boards for Side Marker replacement using this method.
Old 06-10-10, 01:53 PM
CPMD
CPMD's Avatar
Good D.I.Y. with pics
Also, F.Y.I., if one wanted to put HID's in the fogs, this is the way to do it. Just mount the ballasts in those housings. What I did was I mounted the ballasts vertically, so it would be away from water, as there are some small holes horizontally in the black plastic liner. I added a relay, and ran it via the passenger side housing, up to where the battery is
Old 06-10-10, 01:57 PM
RONSKI23
RONSKI23's Avatar
you could also place the Ballast in the Engine Bay.
Old 06-10-10, 02:05 PM
sakataj
sakataj's Avatar
you can do that or like i did,i mounted my fog ballasts vertically on the backside of my crash bar....keeps them out of the way
oh guys if you wanna reduce the theft to these fog lights,do like i did and use a allen bolt in the phillips head screw or do like im fixing to do and get some star or security bolts (im getting mine from a buddy who does elevator repair.NOONE i know carries or owns a security bolt tool so i feel safer with them)
Old 06-10-10, 02:13 PM
skiz88
skiz88's Avatar
Yeah I did feel around in there trying to find a place where I might be able to mount a ballast someday. Would you just use the double sided sticky tape? I'd hate to see a ballast dragging under the car when it came loose.
Old 06-10-10, 02:18 PM
CPMD
CPMD's Avatar
Lol I just logged on to mention the allen screws The size of the screws are 5mm x 16mm, and you can pick them up at home depot for a few dollars.
Old 06-10-10, 02:21 PM
CPMD
CPMD's Avatar
I used 3M double sided tape. I'm pretty sure I used zip ties as well. To my knowledge, it has worked to date (I haven't opened anything up since last year when I installed them lol).
Old 06-10-10, 04:57 PM
5t341th
5t341th's Avatar
thanks for the thread sizing. i was interested in it, thanks
Old 06-10-10, 08:13 PM
McKrevice
McKrevice's Avatar
sub.t for thread sizing
Quick Reply: DIY: 2nd Gen GS Fog Light Bulb Replacement
