2007 3GS NAV/DVD/CD Override plug-n-play kit test results - it works!
Lee
and main difference is warranty, take a look here
https://www.clublexus.com/forums/gs-...-at-times.html
if he had wire cutting, i don't think the dealership would honor the warranty. i actually know of 2 other cases already where the owner has problem on head units and talked to dealership. they have the prestigious kit and dealerships were ok about it. of course that's case by case i guess
If that model number is wrong, can you let me know which model did work with your GS450h (with Mark Levinson).
I didn't do pic's, but here's the step by step:
1) Disassemble the switch (2 screws at the bottom)
2) remove circuit board and buttons (rubber buttons are all one assembly - do NOT damage the small "tentacles")
3) Using a ruler, mark the center of the factory blank (top and bottom, long ways)
4) Measure the center (short ways)
5) draw lines to create a "cross hairs"
6) align the buttons to the cross hairs for centering and trace
7) use a small drill bit to drill a "starter hole" for each button in the very center of the traced circle. This mod requires TWO holes (one for each button, in case that was not obvious)
8) Use a wedge bit - don't know the exact name - it's a round bit, which is pointy at the tip and graduates to a larger bit as you progress UP the bit. Use this bit to GRADUALLY increase the size of the holes until both buttons fit and will move freely. Note that this bit makes a very smooth hole, much better than any other type of bit whcih may create a jagged hole requiring filing/sanding.
9) Use either super or gorilla glue to glue the buttons in place on the underside of your freshly drilled blank - glue the tentacles ONLY (you will understand this once you've opened the switch).
10) Bend the wires attached to the circuit board out of the way, to form an L between the cable and circuit board so the circuit board can be placed into the blank without modification of the blank.
11) Use a grinding tool to "gently" and "slightly" grind down the short side edges of the circuit board. Make sure that you do not accidentally grind down any tracers (metal contacts).
12) place the circuit board into the blank - make sure that the end AWAY from the wires aligns with the "NAV" button.
13) Using the bottom piece you removed from the original switch, place the circuit board into the botom and firmly push the whole assembly/circuit board up to the buttons. While holding the board in place, align it so that you can press each button and hear an audible click (confirmation that you have achieved alignment). The inclusion of the original switch bottom allows easier placement of the circuit board and less material required for step 16.
14) Then carefully use gorilla glue or superglue to lock the circuit board in place...
15) Continue to hold the board with your finger and blast it with a couple of blasts of compressed air or C02 which will help accelerate drying.
16) Using SILICONE (the caulking type or type from home depot in a tube, make sure it is NOT SOFT DRYING) Cover the circuit board and bottom of the blank - USE YOUR FINGER FOR APPLICATION for best aim/control.
17) Wait 24 hours for Silicone to cure and harden....(You can snap it carefully into place while you wait).
Voila - you will still need to be somewhat gentle - don't pound on these buttons.... but it works great!
Notes: If this doesn't hold, I plan to use epoxy to seal the bottom, but I think the Silicon is a better approach so that it doesn't damage the board. Epoxy on TOP of the silicone will be fine, for anyone trying it. The silicone is the same stuff they use to SEAL a circuit board from the elements...
Note #2: I am a big fan of JB Weld, but this will NOT work on plastic and MAY actually damage or "eat" away at the circuit board, so I would not attempt this.
Note #3: Summer is a perfect time to do this modification as the heat will speed the cure process on both the glue and silicone.
Enjoy!
Again: I take NO responsiibility for your actions on this or any damage you do to the PS mod, your vehicle, etc., but I do wish you luck! <---Note added because we live in a litigious society LOL
