View Poll Results: How long do you warm up you engine
None, start it and go!
305
36.40%
About 20 sec., until rpm drops to 1200.
321
38.31%
About 2 min., until rpm drops to 1000.
176
21.00%
However long it takes to get water temp up. (post what temp)
36
4.30%
Voters: 838. You may not vote on this poll
How long do you warm up your engine?
Old Nov 3, 2007 | 10:27 PM
  #151
LexusIS-TL's Avatar
LexusIS-TL
Originally Posted by Gernby
Idling is bad for an engine regardless of temperature!
No one has an answer to this?
Old Nov 5, 2007 | 03:49 PM
  #152
Gernby's Avatar
Gernby
Sorry ... didn't notice the question...
Piston rings rely mostly on the gas pressure of combustion to press them up against the cylinder wall. At idle, cylinder pressure is low, so there is a lot of "blow by". When the engine is cold, this is even worse since much of the blow by is water. The water and other combustion products contaminates the oil.
Old Nov 5, 2007 | 03:53 PM
  #153
LexusIS-TL's Avatar
LexusIS-TL
Oh, good explanation. It's just that have you notice on a cool or cold morning, your car will be knocking like crazy if you drive it right away? Once it's warmed up, the noise completely dissapears besides the normal light ticking sound. Like this morning, I tried just taking off even though the outside temps is like 51 degrees. Wow, it literally sounds like something was tapping under the hood. Then after about 5-10 minutes of driving, it's gone completely. What could that be caused by?
Old Nov 5, 2007 | 04:00 PM
  #154
Gernby's Avatar
Gernby
I don't know what would cause that. I've never noticed mine to make any noises to be concerned about when cold.
Old Nov 26, 2007 | 11:16 AM
  #155
GordoNx3o9's Avatar
GordoNx3o9
Is this only for new cars? I warm up my engine on cold starts until the needle drops a little bit, then drive off easy on the gas until temp is normal. But for my old cars I've always let it warm up for few minutes before moving.
I fell asleep in my car with my engine idling for 2 hours the other night, is that bad? lolz
Old Nov 26, 2007 | 11:27 AM
  #156
ReLexin's Avatar
ReLexin
i give her 2 mins to warm up. my dad has always done this so i guess i have a habit of doin it too.
Old Nov 26, 2007 | 02:17 PM
  #157
2SwiFt29's Avatar
2SwiFt29
i usually just wait until the temp needle starts moving to the line and drive normally until it's stable...
Old Dec 8, 2007 | 07:39 PM
  #158
Lextasy89's Avatar
Lextasy89
my car lagzzzz like crazy until I've driven for a few minutes and the temp stat is in the middle
Old Dec 8, 2007 | 09:05 PM
  #159
aequitas3's Avatar
aequitas3
Well since I live up in the northeast, I have to wait a couple minutes... lol
But at least the seats are nice and heated by the time I'm ready..
Old Dec 8, 2007 | 09:57 PM
  #160
LexusIS-TL's Avatar
LexusIS-TL
A modern engine doesn't need to be warmed up before you drive it. The only exception would be if you lived within a few hundred yards of the entrance ramp to a freeway, and you had to start the car and merge into 80 mph traffic within about 30 seconds. Otherwise, you're just wasting fuel. 30 seconds or so is sufficient. I should also add that letting your engine idle for long periods of time will cause excessive wear and actually slows the warm-up process considerably. An engine under load will warm up much more quickly than one that is idling.
The temp gauge shows your coolant temperature, not the engine temp... If you give your car several seconds to work the oil around all moving parts and don't run your RPMs past 2500 (on a regular combustion engine) for that first 5 minutes, you'll be fine.
Old Dec 9, 2007 | 11:27 AM
  #161
GordoNx3o9's Avatar
GordoNx3o9
Sounds good.
Old Dec 9, 2007 | 11:33 AM
  #162
ES3's Avatar
ES3
Is there an engine temp guage in any of the computers of our car that we can access? Also, is there a digital temp for the coolant somewhere in there too?
Old Dec 9, 2007 | 09:40 PM
  #163
z4frosik's Avatar
z4frosik
In the winter i try to wait until the car is not below freezing any more
Old Dec 10, 2007 | 06:29 AM
  #164
Gernby's Avatar
Gernby
Coolant temp is available via OBDII, and there are some pretty cool "guages" that will display it.
Old Dec 11, 2007 | 08:27 AM
  #165
phatboyc's Avatar
phatboyc
I wish we had oil temp like the BMW's. That would be sweet.
