FS: Front & Rear GS/IS350 OEM/Advics BBK
*SOLD*
Up for sale is my OEM front & rear IS350 brake system. Included are all four sets of calipers, pads, lines, and rear rotors. NOT included are the dust shields or front rotors. I'll include the front rotors if you want, but they are at minimum recommended thickness and should be replaced. You can get brand new OEM Centric blank front rotors for $53.39 each online. See picture below. BTW, the splotches you see aren't stains - it's WD-40 (I was test-fitting IS-F brakes and had to remove the disc, caliper, and hub). As you can see, the front calipers have Lexus brushed aluminum decals applied. These can be removed if you like, but I'm leaving them on in case the new owner wants them. Asking $500 for the full system. Considering Sewell sells ONLY THE FRONTS for $999, this is a steal of a deal. I'd prefer a local sale, but will ship at buyer's expense. http://farm4.static.flickr.com/3646/...e6cba521_o.jpg Javier |
JavyLSU has my vouch for sure! :thumbup:
BUMP! |
awesome deal for 250 owners wanting to upgrade.
wow great price javy.
Monday bump.
Javier |
Are the rear brakes different on the 350 and 250?
Yes, the 350 discs are bigger and also vented. 250 rear discs are not vented, IIRC.
Javier |
willing to split front and rears??? so i need to replace the front rotors??? so effectively... i'll only be buying the bigger calipers huh?
At this price I'm basically giving the rears away. I'd rather not split up the set, since I wouldn't sell the front calipers for any significantly less amount.
Javier |
Javy, will these fit directly on the 250 awd without any modifications? basically, remove old ones, mount these and go? i'm interestd
i just did this swap 2 weeks ago. It's pretty much a straight swap. very good deal! :)
Originally Posted by XprincoX
(Post 4367347)
Originally Posted by lexboi250
(Post 4367310)
Javier |
Are the diameters of the rotors the same between the 250 and 350? I'm just wondering if it's necessary to change the dust shield?
Originally Posted by eskae3
(Post 4367893)
Sale pending.
