FS: 2000 GS300/400 Masterkey Transmitter
Just take the internal transmitter off this key, and transfer it over to that eBay one.
http://cgi.ebay.com/ebaymotors/LEXUS...spagenameZWDVW
Just type "GS400 key" on eBay. Here's one for you at $9.99!
I don't know... I'm only here to sell the transmitter. It's up to you to find the key blade.
I can't gaurentee anything since I'm not selling the key...
While searching on CL, I read someone got a $15 key from eBay and it works fine. A blank is a blank to me...
i will buy it, PM send thanks
Here's instructions on how to program it. I followed it this morning and programmed one of the keys.
FOR CARS WHERE YOU WANT TO CREATE A SPARE KEY:
Before starting, press and release the Brake and Accelerator pedals at the same time.
1. Place an already programmed Master key in the keyway (Do not turn on)
2. Press the Gas pedal 5 times.
3. Press the Brake pedal 6 times.
4. Pull out the key.
5. Insert the new key but DO NOT turn it on.
6. Press the Gas pedal just 1 time and wait until the security light stops blinking (about 1 minute).
7. Remove the key and press the Brake pdeal 1 time. The cycle is now closed.
The programming mode will end after 10 more seconds.
REGISTRATION OF RECOGNITION CODE
1. Open driver door, keep it open and in the unlocked position (all other doors should be closed)
2. Put original key in ignition and pull out
3. Lock and Unlock the doors 5 times (complete each lock/unlock cycle within 1 second and
entire process in 40 seconds or less)
4. Close the door and open the door
5. Lock and Unlock the doors another 5 times (complete each lock/unlock cycle within 1 second and
6. Put the new Master Key in the ignition, turn it to "on" and then off (with 1 second) and remove from the ignition.
7. Press and hold transmitter LOCK and UNLOCK buttons simultaneously for at least 1.5 seconds,
and then within 3 seconds; press any transmitter button for at least one second.
8. If within 3 seconds, door locks cycle one time, new transmitter code was accepted. If door locks
cycle 2 times, new transmitter code was not accepted. If code was not accepted retry step 8 again.
ES214
04-30-16 11:10 AM
KingPHAM
08-12-08 03:03 AM
