TX is300 fuel return kit with pump
I have here a complete custom is300 fuel return kit for sale. If you are going na-t or doing a gte swap this is what you need.It contains a fuelab fpr and walbro fuel pump, using quality Summit racing fitting and line. This is everything you need minus injectors. With good injectors, this kit can support up to 600hp+. $500 shipped to the lower 48 states. Call or text 713-884-7160 if interested.
Part list:
Fuelab fuel pressure regulator, (its the -10an model, but i used all -6an fittings)
New Fuelab fuel pressure gauge
New Walbro 255 lph pump, with installation kit
New stainless steel lines, 11-12 ft
all new neccesary fittings
Sc300 fuel rail, drilled to accept -6 an fitting
Part list:
