i need traction!!!!1
Old Nov 3, 2005 | 05:29 PM
SUPRMSC's Avatar
SUPRMSC
Theres no way you'll beat Chino. He's the god of 1jz's, you're just roadkill in his way.
Old Nov 3, 2005 | 06:09 PM
VJ RC51's Avatar
VJ RC51
k, well he might be the god of 1jz
but i got one dollar saying i can go 13.5 on stock psi and no electronic addons in a few months
Old Nov 3, 2005 | 06:18 PM
Aristo300's Avatar
Aristo300
Well you made too many different post to just quote one. It won't take a 1.8 60ft to go 12's....... a 1.99 60ft will send the car into the 12's no problem, but the problem is I don't see you taking the plunge into 1.9x 60ft territory on stock boost or stock exhaust. The time you ran last night could have easily been a 14.0@100mph with a 60ft of 2.2..... which shouldn't be to hard to attain. My car bone stock has cut a 2.36.... and my car is SLOW off the line. I don't care about what traction problems you may have...... I can put together a 1/10th or 2 lower 60ft with the extra power. Hell even if you have to leave a little slow.. it can happen. I'd suggest you get some good rubber on there and take it back out to the track on the SAME setup.... I guarantee you can net a 13.90/14.00@100mph - EASY. I'm waiting for DaveH to get this cheap LSD on the road..........
Old Nov 3, 2005 | 06:22 PM
plex's Avatar
plex
1UZFE/2JZGTE
after chino huh what is this a battle of the garnett 1jz's?
Old Nov 3, 2005 | 06:26 PM
VJ RC51's Avatar
VJ RC51
Nope, i'm going after my friends supra... he runs 11.7 @ 125. I got a long way to go!
Old Nov 4, 2005 | 04:03 PM
codetoad's Avatar
codetoad
Hey, at least you guys have a 1/4 mile track to race at... I got a sharty 1/8th mile track like 20 mins away but the nearest 1/4 mile track is like 4+ hours away. They are supposed to turn it into a 1/4 mile track but I don't see it happening anytime soon.
So I guess I'll try and own your 1/8th mile times once I'm not slow
what was your 1/8th time by the way
Old Nov 4, 2005 | 08:53 PM
got_trd's Avatar
got_trd
ok, fyi: my 13.5 was withOUT mods... all these posts your making makes it like my car is modded when i did that... get ur **** str8...
that was with a 2.196 60' btw... STOCK
You assume im fully modded now? lolz... stock ypipe/downpipe, stock cams/gears, stock ecu, stock fuel, stock map, stock tranny, stock head/block.......... wth are u talking about fully modded? the few bolt ons i have??? u have no clue what i have done.. and you think your king dingiling cause u trapped 100?? i can do that w/ pos 245's too buddy.... my first run ever in the car, i did 14.1@ around 100 stock on stock boost w/ a 2.3 60'
keep trying buddy.... i ran my car in like may when it was hot as ***** out too... not in this nice cool weather we have now....
Old Nov 4, 2005 | 09:03 PM
ki_soarer's Avatar
ki_soarer
get em boy... im dont think im going to get involved... you two just line up at the track!
Old Nov 4, 2005 | 11:06 PM
Aristo300's Avatar
Aristo300
Old Nov 5, 2005 | 08:10 AM
soarer479's Avatar
soarer479
what you need is some 11in wide in the back with bfg g force drag radials i bet you couldnt burn out in 1st if you wanted too
Old Nov 5, 2005 | 09:39 AM
Aristo300's Avatar
Aristo300
Open Diff=lightEMup
Old Nov 5, 2005 | 11:03 PM
VJ RC51's Avatar
VJ RC51
I was there that night or did you forget that, and forget telling me that you raised the boost even higher that 13.5 run, over 1bar you said, to try and attempt to get your goal of 13s.
You were out there running for broke, tryin to break the 13s.... What about those 14sec runs you put down at lower psi?
It's ok tho, you can now claim that run was "bone stock" because im 4mph slower then you with a 100% stock 1JZGTE, at that time with a shop rag as the air filter, and an open LSD, whatever makes you look better.
I have no aftermarket gauges in my car, no non factory electronics. I can not turn boost up or change fuel settings because there is nothing to adjust.
I'm not calling you out, just don't give out false information. Turning up the pressure with a boost controller and having an SAFC2 and claiming its for viewing only, isnt bone stock. You shouldn't be putting my car down, you should be questioning yours, why you have an LSD, wider tires, boost/fuel controllers, pullys, air intake, and it only ran 4mph faster then a car with the same exhaust, open dif, OEM fuel and boost controls, and a 60ft that was .2 slower, that was installed in some garage by a guy and his father that never worked on or touched a toyota/lexus in their life, with motor bought off ebay. No wonder you hate me, cause if i were you, that would really **** me off.
My first run of the night was 14.7 @ 97mph with a 2.5
my 2nd and final run was that 14.4 @ 100mph with a 2.4
Lets follow that pattern and if i pulled a 2.2 like you, well that would = around a 13.8 at around your same MPH. Your car seems pretty slow to me for what it has done to it. Again i'm not calling you out... but maybe you should do a tune up or something, its running slow.
Old Nov 5, 2005 | 11:23 PM
codetoad's Avatar
codetoad
Imitation is the most sincere form of flattery
Old Nov 6, 2005 | 09:30 AM
ki_soarer's Avatar
ki_soarer
i have to step in here. i know for a fact that chinos car was stock that night. first off, his first run was on stock boost... the boost controler wasnt ever powered up. secondly, the safc was not set at all. we were looking to have it dyno tuned before we went to the track, and it didnt happen. third thing... his car was running like crap that night... i know because when we changed the pluggs next time, the gap was off a bit. it was probably about 20 or so degrees hotter when chino ran as well. as far as the intake goes, all he had was a cone filter... your shop rag probably let more air past than a cone filter. the only difference in the two cars when taken to the track was the LSD, and the driver. you clam to have lots of experience on the drag strip, so maybe thats why you were only 4 mph slower.. you can drive better? if your looking at the mph, i think your wrong about saying he is slow with all those "mods" (ok, he had an LSD)... my stock SC ran at 89.7mph with 87 octane gas in it! so your saying that my car is only twice as slow as yours than yours is as chinos... WOW, with a 1JZ, your car must be screwed up, because my GE is only 10 mph slower in the traps!!!! see what im getting at? the only way to know for sure, is get an LSD, then go back to the track when its about 80 degrees at 8:00pm.
Old Nov 6, 2005 | 09:43 AM
DETUNED's Avatar
DETUNED
Another way to settle it is to run each other. AND get it on tape
Peter
