FL HRE 540 Step Lip 19x10 11 Aggressive!!
HRE 540 Step Lip 19x13 Aggressive!!
Like the title says i have a brand new set of HRE 540 wheels that are step lip. i bought them used and had them completely redone by Spin-tech. stripped and repainted the faces the original color a charcoal grey. All new HRE hardware (nuts and bolts) polished with clear coat. Replaced the outer barrels with new polished 5" and 4" ones. Original ones were 1.5". have brand new stainless steal valve stems.
19x10 et -19 4" lip
19x13 et -31 5" lip
lug pattern: 5x114.3
asking $3800.00 OBO.
looking for local south florida sale for now
call or text me anytime 561-213-7851
19x10 et -19 4" lip
19x13 et -31 5" lip
You get -1.25. You convert that to mm you get -31.75. Which is your offset.
That's how I learned. Not sure if im doing it wrong or not, but I've been doing it that way for a while.
Okay so this is how I measured the offset. The wheels is 13 inches wide right. You divide that by 2. Which gives you the center line. Which makes it 6.5 inches. Then you measure the back spacing. Which is from the hub to the rim edge. I got 7.75 inches. Then you subtract the back spacing from the centerline
Good luck with the sale.
7.75-7=.75 inches so 19x13 +19 offset.
Vertex GS3
17
01-01-16 10:54 AM
Kumar350
14
08-12-14 05:47 PM
TokerIS350
Wheels and Tires Classifieds
10-10-10 04:08 PM
Jsy622
06-07-08 01:21 PM
bonsaiGS
20
07-14-06 05:01 PM
