AL FS: Lexus Rims, 19x8.5 F, and 19x9.5 R, with tires, lugnuts, and rings
1JZ Single SC400
I have a used set of chrome ADR decadence style design set of rims. The size is listed above and I have no clue of the offset. They were on my 92 SC400. No rubbing issues in the front on stock springs/struts, but if lowered alot you need to relocate your wiring harness and remove the black metal trim in fender well. For the rears you will need to grind down the inside metal lip all the way flat for these 275 to fit without any rubbing issues. They are approx. 4 years old and have no scratches, dents, dings, not warped, nor need tires. I had a flat and all they had was a used 235/35/19 for it, so I let them put it on, that's the reason for the miss matched tire. All the others are matching. If you want a matching tire size and brand, add $65 and I will have one put on. If you need more detailed pictures of them, let me know of which area.
Front tire size is 245/40/19 on the right front RFT Bridgestone Potenza
Front tire size is 235/35/19 on the left front, Nexen 3000
Rear tire size are 275/35/19 on both with matching RFT Bridgestone Potenza's.
I am asking $500 picked up, this includes all the lug nuts and hubcentric rings. The lugnuts have some surface rust due to the chrome coming off, so be aware.
I am willing to meet, but must put a 1/2 deposit down paid through Paypal as a gift, and will only go about 100 miles from 35613. Look at my trader score if you think I own junk. Text/call or PM at 205-482-5533.
Rear:
Fronts:
Lug nuts and rings, the other ring is still on rim...
Rear:
Fronts:
renren7
SC- 1st Gen (1992-2000)
05-27-09 03:30 PM
