CA ICHIBA V2 5x114 spacers 20mm x2 and 25mm x2
these were purchased from west covina Nissan. they go for $130 on amazon.com each pair
Ichiba V2
hubcentric with built in studs.
$99 for 20mm
$99 for the 25mm
I have one 4 prong lug key so should ideally go to one person. gotta find the other one...
will sell both for 190 FIRM.
located in pasadena CA, pickup only. will meet you in temple city, arcadia, pasadena.
these came off a 350Z, used for about 6 Months. not sure what else they fit but I would guess most of the cars on this site. please confirm prior to purchase.
similar set just sold on CL for 90 bucks in one day.
https://www.clublexus.com/forums/whee...ml#post5387135
Description: Version II wheel spacers are made from Aluminum/Magnesium alloy. They are incredibly strong and very lightweight. Each wheel spacers are two pieces design with pressed studs. Now it's time to bolt-on without any swap studs hassles. These are hubcentric spacers that is specifically made to each vehicle; will fitted on your vehicle's original hub perfectly without any gap. Wheel spacers move the wheel out from the hub, effectively widening the stance of the vehicle and lowering its roll center. This simple modification increases lateral stability, which in turn provides improved handling & greater safety.
http://www.amazon.com/Nissan-300Zx-I.../dp/B0036W0NQA
Ichiba V2
$99 for 20mm
$99 for the 25mm
they will fit but are not hubcentric to our cars
as for studs, you would need to use lexus thread lugs on th spacers and then nissan lugs on your wheels.
sell these on g35driver/my350z/zilvia/ etc
