I have a full set of spacers (front and rear). They are made by Project Kics. I have a set of 10mm front spacers, and a set of 15mm rear spacers. The 15mm spacers also have the hubcentric rings. The 10mm spacers do not have the rings, as they are not available. I searched online and found them selling for $139 for each set, plus $30 for the hub rings. I am asking $225 shipped for the full set. They are used, but in good condition. I used them on my IS250 with stock wheels and also G-Spiders, with great results. These are the type of spacers that bolt onto your existing studs, and have new studs attatched to the spacer. Comes with all the hardware needed to install them.
I have iforged daytonas 19x8.5 front and 19x9.5rear 235fr 275 r offset is unknown
best thing to do would probably be to measure the distance from the tire to the lip of the fender.. 15mm is a lot.. 10mm might work.. im not sure how close you are to being flush right now
