Air issue continue
Old 01-16-14, 12:18 PM
Greg5OH
Greg5OH's Avatar
Originally Posted by Riksgs808
maybe there's a leak at the valves. thats the only way tank and line pressure will drop at the same time. just noticed a leak in my tank this morning. dropped 20 psi over 10hours time. had to take the truck to work to be safe
perhaps, but the rate of pressure drop on tank vs bag is more on tank. 30 psi tank drop vs 10 psi bag drop.
coudl it be a valve in the vu4 manifold not fully seating?
Old 01-16-14, 01:31 PM
Greg5OH
Greg5OH's Avatar
here, thsi video might work now:
Old 01-17-14, 06:27 AM
Greg5OH
Greg5OH's Avatar
well ill be damned. the tank stopped leaking. same psi overnight. maybe was dirt trapped in valves.
Weird thing though, it has a cross bleed issue it seems. front rigth goes down a few psi, front left goes up a few psi...
Also when pumping up both front at same time, the front right (furthest from teh manifold) is always underinflated by like 10 psi compared to left bag.
Old 01-17-14, 01:34 PM
Riksgs808
Riksgs808's Avatar
what did you do to fix it? Or did it fix itself?
Old 01-17-14, 10:51 PM
Greg5OH
Greg5OH's Avatar
totally fixed itself lol. I figured might be some crud stuck in the manifold somewhere. Even if it was, i dont know where the air was going to...anyway pumping up and down buch of times, was still leaking. Drive it to the gym and back, then noticed tank pressure was solid, and it held ever since...weird.
Old 01-18-14, 01:51 AM
Riksgs808
Riksgs808's Avatar
huh, thats wierd. hopefully that happens to me. lol. I got home from work today, checked all my fittings and lines with soapy water..... can't find a leak anywhere. but psi in tank drops about 15 psi over 7 hours
Old 03-02-14, 05:47 PM
swtjlsy
swtjlsy's Avatar
does it drop at night time???? you do know that air does expend doing the day
Old 03-03-14, 08:07 AM
Riksgs808
Riksgs808's Avatar
I do know that, but it would drop like almost 40 psi every day after 4 days it would be at 0psi. But like the op, it stopped leaking like 3 weeks ago. Weirdest thing. I still don't even know why it was leaking. Now it only drops like 3-5 overnight but day time is fine. So I'm not worried about it.
Old 03-07-14, 07:50 AM
Greg5OH
Greg5OH's Avatar
swtjlsy i have to say i finally understand what you mean with elevel that it will manage everything.
My systme uses the traditional pressure sensor which is connnected to the solenoids which turn the compressors on and off. Basic system, on this psi off this psi. Just realized e-level will adjsut your on off pressures automatically to make sure you have enough pressure to get to full height without the compressors turning on. SO my system is a 150psi system, and witht e volume of the lines, bags and tank, the compressors will turn on if i try raining all 4 corners at once from full dump. I tried a bunch of 175 psi switches which didn't work (i realize i had them wired differently)
but elevel will find the perfect pressure for you!.
elevel-one day...dont have 1k for it currently.
Plus I dealt with shay quite a lot regarding my vu4 last week and he was always helpful and courteous, vs dakota digital tech support...the guy was telling me the solenoids which let air in or out send a signal to the dakota ecu to tell u what pressure the system is at.,...i hung up the phone.
getindavan
Suspension and Brakes
03-16-16 11:59 AM
MrFairlady
12-06-11 11:05 PM
rustednail
VIP Style
11-25-10 04:51 AM
agood1
GX - 1st Gen (2004-2009)
01-11-10 07:16 PM
ummagawd
49
12-06-08 12:11 AM
Quick Reply: Air issue continue
