need help with failing air setup
Old 09-03-13, 08:08 AM
swtjlsy
swtjlsy's Avatar
If you are lossing a good amount of air then the compressor will continuously all the time you did not here the air leaking out at all before? The relay failure can be stuck on if there is a spike in power or loss in power when the system is on. The relay arks a little when it switch on and off so it can weld itself together. Good luck hope you get this fixed.
Old 09-12-13, 12:17 AM
sojah
sojah's Avatar
Originally Posted by Celsior21
The tank cracking might be caused by the compressor continuously pumping. I would attempt to put a gauge at the tank to monitor it. If it is a relay failure the compressor should not kick on, it should be toggled by your pressure switch. My guess would be a faulty pressure switch that led to your tank issue.
yeah possibly or probably. but now the power lines have been beefed up (fuse too), and a new pressure switch installed. waiting on the tank to show up in the mail (been slow lately)...
Old 09-12-13, 12:18 AM
sojah
sojah's Avatar
the compressor and the tank are right next to each other. couldn't hear the leak over the sound of the compressor i guess. you can definitely feel the air rushing out as the compressor is/was pumping air into the tank though.
new tank on the way, new pressure switch already installed, should hopefully be a smooth fix.
Old 09-29-13, 04:29 PM
sojah
sojah's Avatar
so new tank (thanks platinum) installed everything should be good.
well there is now a leak in the only few month old smc check valve. what the heck man¿¿¿ are these smc check valves known to fail only after a few months?
Old 10-16-13, 04:11 PM
sojah
sojah's Avatar
after changing out a fairly new smc check valve with a brand new smc check valve problem is now solved. no more leak!!!
GH5T
08-24-13 04:45 PM
heyarms
10-28-12 08:32 PM
wildace
09-16-10 12:02 PM
Woogie
Maintenance
07-30-04 12:53 AM
LSPiNoY
10-16-02 12:46 PM
Quick Reply: need help with failing air setup
