Accuair Elevel installs
Old 12-10-12, 09:17 PM
joerogan
joerogan's Avatar
Very clean set up mike
Old 12-12-12, 02:40 PM
swtjlsy
swtjlsy's Avatar
The interior look sick MIke
Old 12-12-12, 04:36 PM
Mike1970
Mike1970's Avatar
ill post some complete pics of my car soon.
Old 12-12-12, 07:34 PM
swtjlsy
swtjlsy's Avatar
Mine is in process also should be done by end of the yr.
Old 12-14-12, 12:56 PM
c-low
c-low's Avatar
hey swtjlsy sorry about the incomplete info about what i ordered, i actually called Accuair and they overnighted my stuff so today they are suppose to arrive! cant wait to start mounting everything. i sent my tank off to texas so a buddy can do some "work" on it. so slow updates.
so far i have
-- 2 airzenith ob2 compressors
-- 7 gallon aluminum tank
-- accuair e-level w/rocker switch
Needed
-- I-level
-- air line which size would you reccomend?
how Necessary is it to use water traps? I live in WA not humid at all just damp all the time. or is it better safe than sorry?
Old 12-14-12, 02:03 PM
swtjlsy
swtjlsy's Avatar
so far i have
Needed
-- I-level
I would run 3/8 line and the Ilevel is a very cool addition to any set up, sounds as if you are off to a good start, the I-level would still give the touch pad as the one that comes with the E- level jsut on your phone. Let me know if you need any help. Water traps help in any system I would recommend them if you don't have them.
Old 12-14-12, 02:15 PM
c-low
c-low's Avatar
thanks for the info which water traps do you recommend? 1 for each compressor im assuming
Old 12-14-12, 02:18 PM
swtjlsy
swtjlsy's Avatar
Talking
You can use any water trap you can find Accuair does have some for Sale, and you should allows use one per compressor
Old 12-14-12, 02:29 PM
c-low
c-low's Avatar
change your signature pic. im getting jealous. =/
Old 12-14-12, 02:35 PM
swtjlsy
swtjlsy's Avatar
sorry well get on it and get it installed lol.
Old 01-02-13, 02:49 PM
lexusondubs
dubsonlexus
lexusondubs's Avatar
were do you mount sensors ?? how do you adjust them to have the car sit perfectly level ?? (LS 460)
Old 01-06-13, 10:36 AM
swtjlsy
swtjlsy's Avatar
The e level is self leveling so there is no adjustment also long as the four corner sensors are mount in the same area as each side. there are several members on here who have had them install I have yet to do a LS but if I saw the underside I could help you out. PM when youare ready to get something and I can help with the install.
Old 01-14-13, 12:33 AM
lbintab
lbintab's Avatar
Is there a limitation on the travel (up and down) with the sensors? Reason I ask is when I do my setup I plan on having the car at stock height for my ride height.
Old 01-24-13, 08:53 AM
swtjlsy
swtjlsy's Avatar
the sensors have a range of travel which mean you want to mount each sensor as close to the mounting point of your suspension travel. It called the pivot point, this where you mount linkage for the height sensor.
Old 01-29-13, 11:53 PM
lbintab
lbintab's Avatar
Now wouldn't mounting the linkage close to the pivot point also lessen the sensitivity of the sensor detecting a change in height at any particular corner? The closer to the pivot point the less the sensor will move... Are the sensors sensitive enough to see even mm of change in travel of the linkage?
Quick Reply: Accuair Elevel installs
