Life on air: Don’t forget to drain it
Old 09-07-12, 09:11 AM
masboy
masboy's Avatar
Default Life on air: Don’t forget to drain it
just saw this article : http://www.airliftperformance.com/20...t-to-drain-it/
how do u drain it if the 'drain cook' at the bottom of the tank ? no space to turn that drain at all
Old 09-07-12, 05:05 PM
vwynn
vwynn's Avatar
get aluminum tank = problem solved regarding rust
as for the water.. get water traps to minimize water capture in tank.
and the easiest way to remove water from tank like yours.. remove one of the fittings and get a thin 1/4 hose and suck it out lol.. preferably clear hose so u can see it before ingesting it.
Old 09-07-12, 06:59 PM
geeznuts
geeznuts's Avatar
I put a valve so I can hook up a hose and let out the water. No mess at all
Old 09-07-12, 07:23 PM
rgarjr
rgarjr's Avatar
u should take off the drain **** and install a PTC fitting on there, then a run a short line to a schrader valve.
http://bagriders.com/modlab/products...ION-VALVE.html
Old 09-08-12, 12:10 AM
masboy
masboy's Avatar
man.....u guys are expert on this!! thank you! i guess i have to empty my tank again to install that...
Old 10-05-12, 01:51 PM
snoop562
snoop562's Avatar
Thumbs up
great idea
Old 10-26-12, 03:58 PM
vwynn
vwynn's Avatar
i wish i could do that :/.. not enough room in my trunk since the clearance on the top/bottom is already tight due to the Nak sub... sigh
Old 05-08-13, 02:02 AM
phenomeno
phenomeno's Avatar
great idea! something to keep in mind when i finally get aftermarket air
Old 05-26-13, 01:27 AM
mililani00
mililani00's Avatar
How often do you guys drain you're tanks ? I only use my lexus for 1day in a week if any
Old 05-26-13, 05:48 AM
quick123
quick123's Avatar
No worries here...my Accuair kit came with an aluminum tank and a water trap
Old 05-26-13, 08:40 AM
SoCal_450h
SoCal_450h's Avatar
I believe you still have to drain the water once a while.....
Old 05-27-13, 01:40 PM
jayhoang
jayhoang's Avatar
I think I'm just dumb (don't confirm it) but where would do I put the water trap? I was only given one with the Accuair kit, but I have two compressors. Do I need to get another one?
Old 05-27-13, 09:52 PM
ADPearl3GS
ADPearl3GS's Avatar
The water traps are going to go after the compressors but before the tank. If you have two compressors, I always hear, its best to have one water trap for each. Hope that helps!!
Old 05-28-13, 07:21 AM
jayhoang
jayhoang's Avatar
That's what I originally thought but started getting confused because there was a bunch of debate on different places to put it.
Thank you! Looks like I'll be picking up another one then.
Old 06-01-13, 12:17 AM
Sonic_RC
Sonic_RC's Avatar
Sorry ADPearl3GS but that not correct. You need to have check valves between the compressors and tank, not water traps. Having the traps between the compressors and tanks will not really protect anything. Moisture will still build in your tank and and go to solenoid manifold which is their #1 killer. You MUST put your water traps between the tank and solenoid manifold and a drain at the bottom of the tank. This will protect your solenoids and allow you to drain the water from your tank as well.
Originally Posted by YaKuZa_GS
The order should always be.
Compressor > Braided hose > Check Valve > Air Tank > Water trap > VU4/Solenoids Valves > Air bags
The there is no reason to have a water trap between the compressor and tank. The water traps are supposed to protect moisture going to the VU4 manifold.
Here's a installation diagram from Accuair. I'll post up a photo of my setup when I got time later today.
geeznuts you sir are an innovator. I just had to use that drain setup for mine too thanks for the great idea
mililani00 I drain my water traps about once a week and tank about once a month even though I have an aluminum tank.
Quick Reply: Life on air: Don’t forget to drain it
