Ksport air on 2IS some questions before installing
Old 07-20-11, 04:52 PM
koksik
koksik's Avatar
Default Ksport air on 2IS some questions before installing
I just got my Ksport air susp and have some questions before installing and Im looking for some tips.
Where I need to install pressure switch and what this switch doing? ( sorry Im noob in this all air stuff )
Where I must put all wires/lines - inside the car or under?
For what I need to be carefull when installing suspension and all components ( Im going to install myself with my mechanic friend in his garage )
Im going to install susp on friday so I hope I will get some tips
thanks
Old 07-22-11, 08:00 PM
sticky4
sticky4's Avatar
What kind of set up did you get?
Pressure switch needs to be off the air tank, grounded on one end and the other connected to the relay to the compressor.
Old 07-22-11, 11:33 PM
koksik
koksik's Avatar
I have just basic kit. I ring to Ksport and they said that one end of power switch going to relay and second somewhere to wires in the car whitch have power on when the car is running ( so when the car is off, no power in wires so compressor is not working )
Old 07-25-11, 05:13 PM
sticky4
sticky4's Avatar
you're right... sorry.
Old 07-25-11, 05:14 PM
sticky4
sticky4's Avatar
This should help.
Old 07-26-11, 05:28 AM
IXI187IXI
IXI187IXI's Avatar
^ that a good diagram.
basically the pressure switch tells the compressor when to kick on. depending on what switch you have, once the psi in the tank drops below a certain point the pressure switch will kick the compressor on and fill the tank with air to a certain point then turn it off.
Old 08-09-11, 11:24 PM
TheBosSC4
TheBosSC4's Avatar
Does the k sport run on two compressors or one? Regardless. Run the lines inside the car. Underneath carpet, etc. I just did my install yesterday on my 98SC400, tein cst on UAS bags, 5 gallon tank 2 4 way electronic valves. 7 way controller. If you have any questions, pm me. I love it, it rides better than any coilovers I have ever had. Handles extremely well, and is adjustable to be slammed, or ride like a caddy.
Old 08-12-11, 10:26 PM
swtjlsy
swtjlsy's Avatar
This should help.
I like my accuair set better all plug and play no wiring needed lol.
Old 08-13-11, 03:31 AM
koksik
koksik's Avatar
Thanks guys for help, I already installed my Ksport susp. Its more simple than on diagram, but that help me a lot! Thanks again
Old 08-13-11, 04:15 AM
c-low
c-low's Avatar
got pics koksik
Old 08-13-11, 04:46 AM
TheBosSC4
TheBosSC4's Avatar
Picssssssssssssssss!
Old 08-14-11, 09:10 AM
koksik
koksik's Avatar
Here You go:
on stock wheels:
On 19 Eurolines:
Old 08-15-11, 01:47 PM
8ohate
8ohate's Avatar
sickkkk...that looks good...
Old 08-15-11, 11:14 PM
TheBosSC4
TheBosSC4's Avatar
wish my sc would go that low. I think its cause on tein cst's.
Old 08-16-11, 08:19 PM
swtjlsy
swtjlsy's Avatar
Nice pics low and slow.
Quick Reply: Ksport air on 2IS some questions before installing
