Adjusted the front coilover and had to rotate the airbag to adjust the height. Tried this with back and the top of the airbag is stationary. Can not rotate. Thank you for your help.
you adjust the bottom piece. and shorten the overall strut body.
1). loosen the lower ring
2). move ring up to where you want to lower
3). rotate/tighten/shorten the lower body to where you want to stop
4). tighten the ring
