Easy street auto pilot and switches(switchbox)
Whats up guys, I was wondering if anyone here kept the switchbox when they installed their Autopilot. Is it possible? I would like to do this. Thanks
I dont know, I'm more used to hitting switches It's hard for me to hit either both front up, or or both rear down with the autopilot as you have 2 press 2 buttons. With my old switchbox, it was only 1 button for either. So I'm guessing all I have to do is splice each wire on the autopilot, and tap in the switchbox? I read that was causing people problems...
Also, I bought this thing because of the preset, and that thing is waaaayyy of.
are you talking about manual rocker switches controlling the air lines or a second set of valves going to the air lines. You do not add your own 12 volts and switches to the existing valves of the easystreet set up.
Anyone who had problems with it butchered the system by "modifying it " then looked for someone else to blame because of their lack of installation .
I also like the feeling of holding the switchbox .. And what is it with easystreet making the psi sensors so close to each other?! You don't have enough room to put the airlines where you want them! I was going to cut them and extend them, but I read it was bad or something
TO calibrate or get a close reading from all the pezio transducers , hold all 4 button to fill up to the max , check pressures.
Wait until the tank refills to max then press it again and check psi . this will give you an idea of sensors variables. Also if you have water and rust in your tank it will get on your tranducers and cause the psi to be off.
I press both together all the time , I guess I have big hands .
Get a electronics engineer to modify it and they can make one button press both on the board.
