Accuair Manifold is a great piece and I've had good luck using them, however one of the advantages to the Asco manifold is that the gauge senders have holes right in the back where they screw in, with the Accuair u need to use 4 T's and the associated fittings for the lines and reducer for the sender. A lot more work if you will be using senders.
