Need Help Deciding ???
HI
I have been thinking about changing my suspension for a very long time.
I can't seem to decide on what to buy.
All input will be greatly appreciated.
AirRunner TC-5 edition OR Platinum VIP full CUP kit ???
Cup kit isnt the same as full on bags. This choice has more to do with personal preference/style than brand vs. brand so to speak
I mean if you enjoy riding low & stiff and have aggressive wheel fitment that you want to keep fairly 'static' most of the time, but want a touch of convenience, go the Cup kit.
If your wheels arent super close to the guards and you dont mind too much about always running around low and flush etc and just want the overall flexibility of different heights for different situations, go the Airrunner..
Which of these two systems would be better in terms of reliability, and maintenance ?
thanks again guys for your inputs
imho the platinum cup kit seems to be a very good bit of kit that doesnt suffer from leakage problems etc as some other cup kits can. And since you are pretty much just on coilovers 90% of the time then reliability shouldnt be an issue. If you have a leak or problem with tank/lines/etc it just means yours cups wont inflate but you can still drive around in relative ease. If you end up too low you just wind the coilovers up so you can get around until you can afford/get time to fix the problem with the cup system.
the quality of airrunner isnt in question, but it just means that if something does break you are effectively stuck until you fix it (and if this is on the side of the road then it could cause issues!)
but again, it really is sort of personal preference. i prefer my ride low and stiff and predictable, with the ability to just raise a bit for obstacles so i would get cups. but if i had a big bodykit and/or couldnt avoid certain situations/passenger carrying etc i would probably go a full air bag system.
Even though there is only small chance of something going wrong with a full air ride suspension (air runner) may be dangerous if an air bag suddenly goes, or put my ride out for a certain amount of days if there was a leak or something as you mentioned. Is something that I would definitely not look forward to after spending that amount of money.
This is a big plus 1 for the cup kit.
I asked Platinum Vip about air in the cups, and I got this answer:
"with our system, it is made to drive aired up. when driving aired up, it is like you were to adjust your coilovers manually." I guess this where the problem of having passengers gets solved. But I do have a lip kit on my GS.
I was also thinking about bold world.
With air bags, the main reason why I am debating against coilovers. Is that there is a small chance it might leak or 'pop'. Especially while driving, it would not turn out good.
I know with companies like air runner and bold world chances are extremely low that a bag will leak or pop. I guess it is a psychological concern more than anything else. After spending 5K or so on the suspension, I really would not want to worry about maintenance.
As for the bold world cup kit, they are really good. The only thing that is making me lean more towards Platinums' cup kit is that I can drive with air in them for long distances and not only to drive over bumps or inclined driveways.
So with the JIC coilovers, I will set it, to a really low driving height, and drive with air in the cups from Platinum VIP. This will give me an extra 1-1.5 inches in height.
When I park, I will 'air out' the cups in order to have the same look as if I had air bags.
