Help!! What did i get myself into???
ok so i did a test fitting on the wheels bought and it sticks out about an inch in the rear and hella flush in the front...wheels are 20x9 30 offset front and 20x10 30 offset rear on my 2006 GS....do u think i can pull it off with 225 35 in the front and 245 35 in the rear???
if you're test fitting without tires, i suspect the car is in the air suspension at full droop. they will come in a bit when you get it on the ground. you may have to lower it more though...
my car is dropped on tanabe dfs....the rims are on the hub and i used a jack to lift it up so its where it should be if the rims had tires...but i will take pic soon becuz i was workin on it at night and couldnt get good shots...
